Hey Guys thought id throw up a phew pics of my car its been on here a couple of times yet I never seem to be able to stop moding it lol.
Engine: RB26DET conversion out of a r32 gtr, bought the engine from perth as a good runner got it over here pulled here down to have a look inside and found 6 scored bores 1 stuffed piston and a main and big end bearing f*cked although block turned out to be a N1 item with 24U stamped on it. Polished and details engine bay
Exhaust: 3.5" off the tubo hi flow cat and 3.5" catback
Suspension: tein
Wheels: new 18" drift r's
Exterior m-sport kit and drift lip genuine gtr ser3 front bar and lip and genuine gtr grill optional gt wing
Modifications:
Currently in the process of rebuilding the engine with ross racing forged pistons, prepped and shot peens rods, ARP rod bolts, bottom end stud kit prepped crank, detail engine block, fully ported head, stage 2 tighe cams with 272in and 264 ex, cam gears, n1 oil pump and water pump, 700cc sard injectors, sard fpr, modified fuel rail, custom exhaust manifold, garrett gt3082r turbo with both .82 and 106 housings, tial 44mm wastgate, nispro ecu, bosche 044 and 3/8" aluminium lines and 2l custom surg tank, jjr alloy radiator, trust intercooler, nismo clutch and lightened fly wheel.
Stereo Audio / Visual: kenwood double din and splits fron and rear
Estimated Power: going for 400rwhp on 18psi with the 1.06 and 450-500 on 24+psi
The engine should be finished soon and hopfully back on the road by the end of march, then a completely new post with the finished results. Just remeber my car doesnt get touch by a shop at all everything is done at home saves heaps of money and doing all this on a 3rd year apprentice wage too
Edited by johnbarry88
https://www.sau.com.au/forums/topic/208674-ants-r33-gts-r-rb26det-conversion/
  • Replies 66
Posted Images
i think i got a phonecall from you, or somebody you know about this engine.
asking me why i had sold them a stuffed gtr engine.
turns out he had the wrong number.
was kinda funny, cause i had sold my rb20 just about two days earlier, but it was to a mate, so i was a little confused at first.
how did it all turn out with the dude in perth?
no dramas. whoever i talked to on the phone was polite, but they just wanted to know what the go was.
shame to hear it died on you, but by the sound of it, onto bigger and better things. that block would be worth a bit anyway.
Nice work, my only comment would be a bigger surge tank (assuming you are running the return line back to the surge tank) as you'll find you may strike fuel heating issues in summer (when fuel tank is under half full), alternatively you can run a fuel cooler on the return line which will help.
Edited by slapper
hey ant, the car is coming along great! if i come up to the bay i'll have to drop in and see how its going! i envy you msn, this thing is going to be hell worth the time and money! cheers cuz, hame
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
