Guest RedLineGTR
Dont think it was real probably something dreamt up by the movie makers, the purpose of the "gun" i think was like a EMP shock wave through the cars metal shell to effect all electrical components like the ecu etc...since 100% of electrical items a grounded they can be shutdown buy this form of a "gun". Dotn know if it's correct but *shrugz...
  • 3 months later...
EMP = electrical magnetic pulse
But the gun in the movie is strictly fictional.
How can they shut down the car in 3 stages, they made it look like it taped into the engine management and started to close it down in stages ...
there are real devices like it but they just fry the electrical system, not shut it down in stages .. but only in america ..
a necleur bomb will stop a cars electrical system .. hahaha and the explosion will do the rest ...
fictional based upon the technology that i believe was used in the gulf war? I remember reading somewhere that some of the missiles were equipped with a form of bomb which only had the effect of frying computers, in particular nano devices like CPU's used in military equipment. harmless to humans (apart from the impact of course)
Wouldn't laugh though, it may just become a reality some day, although i'd doubt they'd waste it on petty boy-racers. :(
yeah there are such things they fall under the 'non lethal weapons' catagory.
The US cops were trying a device that looked similar to a shoe box on wheels, that was shot out from under the front their car, and designed to go under the car they were chasing and discharge an EMF powerful enough to fry the ECU and chips in the car. There is only one problem with this, just imagine if the person in the car has a pacemaker!
Originally posted by holdens_r_better
Id doubt it was real be pretty wicked if it was but
It is real people!!! USA has proto type and seen discovery channel on that EMP.
Its not used at the moment only cuz, scientist doesn not know the effect on Human Brain.
and it is dangerouse to use while vehicle travelling high speed. when engine turns off the car go stray and hit other pople on the road.
cheers
Joe
It would be difficult for that sort of device to be legalised due to the firing of a projectile with spikes on the end.
Can you imagine the shitfiight if the cops aim was off and he put it through the window and into the driver/passenger? LAWSUIT, it is america after all!
Sounds like a good idea, haven t seen the movie yet and dont really care to *shrugs*
Can u imagine the amount of power it would take to shut down a car making however many kw through the alternator. I dont think u could do it with another car battery.
The weapon they used in the gulf was a kinda experimental to say the least.
"1991: DESERT STORM: According to Defense News, April 13 - 19, 1992, the US deployed an electromagnetic pulse weapon (EMP) in Desert Storm, designed to mimic the flash of electricity from a nuclear bomb. The Sandia National Laboratory had built a 23,000 square meter laboratory on the Kirkland Air Force Base, 1989, to house the Hermes II electron beam generator capable of producing 20 Trillion Watt pulses lasting 20 billionths to 25 billionths of a second. This X-ray simulator is called a Particle Beam Fusion Accelerator. A stream of electrons hitting a metal plate can produce a pulsed X-ray or gamma ray. Hermes II had produced electron beams since 1974. These devices were apparently tested during the Gulf War, although detailed information on them is sparse... "
Thats alot of juice and these thing would not be cheap, would proably be cheaper to blow a bunker to simtherines instead.
More reading for any interested More
Yepp, they are around, if you have the right Taliban and US contacts !! LOL
They are a 'little bit' different to whant was shown in the movie though.
For propolsion, the one in the movie would have been using presurised gas or air.
Underwater spear guns use compressed air, and on the flat out setting are totally wicked :cheers:
J
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
