just put my R32 crank into shop to have the oil pump drive collar fitted to tell me the crank is bent?
How do you bend a crank shaft, was running fine all bearings are fine and bearing surfaces are good too. it did lunch # 5 piston hence the reason its out but was running fine until it failed. Cant complain about the piston failure engine had ove 100 k on it and we were sort of pushing it a wee bit.
https://www.sau.com.au/forums/topic/209278-bent-crank-shaft/
very personal question there Russ! oohh BLOCK :-)
i had another of those laying around Squeeky Steves shop.... just waiting for him to call and tell me its warped or the flux harmonic capacitor has .3 degrees run out or such, that would make his day i can hear him gigglin now.
Get the feeling he dont like my fleet of RB26DETT's to much in fact he has renamed them FURKIN26DETT's i think i am just gettin closer to his pet EVO even had to use the excuse my tyres are 04's your are 08's
so in the market for a new R33 crank i guess
Straight six cranks are susceptible to bending purely because they are so long.
Unfortunately it is easy to bend a crankshaft esp in a straight 6...If you lunched a piston then what may have happened is that the engine locked up suddenly on cyl No5 and the rest of it didn't want to...therefore something has to give..it may be bent but also a bit twisted..Just the inertia in the flywheel is enough to twist the crank if it is locked suddenly...
It will still run but the timing will be all over the shop...ie crank is bent but cam shafts are not...I say if you ever lunch an engine get a new crank if you can afford it..
hmm it just broke a ring land on number 5. I think that it is bent on the front where the oil pump drive is although i never felt any vibration and if the piston hadnt failed it would still be running around.
Very strange
meh you aren't trying, it took too long. I've know of 2, one in a motor where the bearing spun (not sure if that was cause or effect though) and another which was just road driven, eventually the bend caused the balancer to rub on the timing cover and bolt to loosen. not good for it really.
just grab another one, cranks are cheap and collars are easy enough to fit.
it all depends how bad the bend is??
If its bent on the collar drive then it can be repaired fairly easily. If its bent half way down then grinding the crank if its only a couple of thou usually is sufficent enough.
Generally every RB26 crank that I see has a slight bend in it. Depends if the owner wants to worry/know about it though.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
