hey every1
i currently have a HKS Fcon V ecu in my R33 GTR. just wanting to know if there is anyone out there who knows where i could get this computer tuned as atm its only got a pretty light tune and i wana push it further.
looking for sumwhere in the sydney area
https://www.sau.com.au/forums/topic/209359-hks-fcon-v-tunning/
  • 3 months later...
Can anybody confirm firstly that there is nobody in VIC who can tune a HKS F-Con V Pro? And Secondly if BD4S are still doing these?
I'm buying a V35 from Japan which unfortunately is running one of these, I don't have the budget to change the management when it arrives and I'm hoping somebody can tune it?!
Will the Japanese tune be ok if the car isn't modified any further?
i had the software and gear lined up but it seemed there was not enough demand to warrant it... $4k for the software... not cheap
The only shop's in Australia that can currently tune the HKS F-Con V Pro are:
TUNEHOUSE in Sydney
Jim Ghelis
11 Chalder Street
Marrickville NSW 2204
02 9557 4000
and
XSpeed in Perth
Hanson Yeoh
18 Zeta Crescent
O'Connor WA 6163
08 9331 8088
From 1st July 2008 Tom at BD4 has not accepted new offer from HKS so is no longer a HKS distributor or tuner. Other shops and people that claim to be able to tune the V-Pro are unable to. Without the HKS dongle key software is useless. They key itself that people claim to have don't work.
I'm currently in the process of working out a HKS Pro Dealer Tuning Network in Aust but it's a slow process due to HKS having to visit and approve all dealers.
HKS and I will be in Sydney/Perth Oct/Nov for more training and release of new F-Con V Pro with current dealers. Any prospective dealers are welcome to email me at [email protected]
So UWISSH! please contact Jim at Tunehouse and tell him Martin reccomended you.
Regards
Martin
2 tuners in australia - awesome
dude, sell it like i said before and buy something locally supported
there are dozens of great ecu's with lots of tuner coverage
there is nothing the fcon does that the other ecu's wont do
If he lives in Wollongong/Sydney I would have thought Tunehouse in Sydney was local support for him. Why go to the expense of changing the computer when he can have it tuned locally.
And also depending on what other ECU's you are thinking unless you go top shelf for Motec of Autronic the other manufacturers are inferior to HKS F-CON. I must admit though it's all about value for money but having a re-tune surely has to be cheaper than buying a new computer.
Regards
Matin
Two tuners in AUS, limits you like a dog with 1 leg.
I'd never have/use any ECU that isnt reasonably well supported around the place.
If you have an issue with the tuner or anything similar, your stuffed. You cant even get help over internet forums etc for it. Not that all forum stuff is right, but at least it aids in trouble shooting etc. Im sure these forums have saved a lot of people, a lot of money over the years :P
IMO - Rip it out, sell it on ebay as paul suggested, and buy a decently accepted ECU.
You'll find it'll probably workout similar in price especially when you considering PFC's are only $900 and anyone can tune it, so for what, $1500 you can have a new ECU installed and tuned. Choice is clear.
All the extra "features" ths F-con might have over a PFC, you simply will never need in a road car also.
Hell, if a PFC is good enough for your 'run of the mill' 350rwkw circuit GTR, cant be that bad for $900 now can it?
I don’t see value in something that I'll
Hey, the guy asked if someone in Sydney can tune his HKS F-Con V Pro. I supplied the answer to his question - whether you like it is another matter. I'm not stealing his thread with mindless dribble. Simple answer is Jim at Tunehouse to his question.
or spend $4k on the software and dongle which is readily available ex japan :P
Martin what is involved in becoming a pro shop? im a greddy pro shop is that an issue?
URAS - Best you shoot me an email at work cause forums are a waste of time to talk if you are serious. And we have purchased many of the so called keys over the years and non of them work.
Cheers
Marty
Cheers
Marty
Yeah and leading the horse to water is also good.
Sometimes it helps to have background information, something that as a HKS supplier you would never tell
thanx for all the input guys but due to the lack of knowledge and availability of tuners i have recently gone out and bought myself a power fc. Atleast this way i know there are heaps of people who can tune it and if i have problems its easy for me to find out how to fix them.
thanx again guys it was much appreciated
