well my 33 GTS-4 has now clocked up 103 xxx kms and i recon its about time i got its 100k service, im worried the timing belt will let go soon, and then big $$$ if it does.
so heres the question
what workshop would people recommend?
and about how much am i up for $ wise?
https://www.sau.com.au/forums/topic/209759-100k-service/
http://www.skylinesaustralia.com/forums/Co...hr-t191756.html
Most of these shops are good for it. Just find one that's near where you live.
Timing belt isn't too expensive. Had one break on my old car... that on the other hand was expensive.. car was never the same again.
https://www.sau.com.au/forums/topic/209759-100k-service/#findComment-3708135
Go to the link that Wogan said to go to.
When I had mine done I paid about $1500 and got the water pump done at the same time with a major service.
Edited by Hotrod
https://www.sau.com.au/forums/topic/209759-100k-service/#findComment-3708157
Just out of interest after how many k's should the timing belt be replaced? I'm going to get a major service soon (just passed 130k's) and I'm going to get new spark plugs, fluids changed, brakes inspected (possibly new brake pads), etc but not sure if the timing belt should be done.
https://www.sau.com.au/forums/topic/209759-100k-service/#findComment-3708469
every 100,000km is the general rule
https://www.sau.com.au/forums/topic/209759-100k-service/#findComment-3708504
Malaga Auto Repairs!! I'm not biased, honest...
I own a skyline, another mechanic raced skylines for 10 years, and another one worked on his daughters skyline all the time. Plus over 100 years experience with 4 mechanics. Need I say more?
5 Inverness St Malaga...
https://www.sau.com.au/forums/topic/209759-100k-service/#findComment-3718306
do it yourself, gather mates and have a bbq.. thread in the stagea section doing it this way. Save alot of $$ and all is good.
bad idea, this equals my diesel mechanic apprentice mate thinking rb25s are exactly the same as the diesel machinery engines hes worked on lol
https://www.sau.com.au/forums/topic/209759-100k-service/#findComment-3719839
but wot if you only drive the car 5000kms in 6 years? Best to stick to the 100,000km rule. Check ur engine bay for a timing sticker, see if it has been done yet. Chances are it hasnt. I think I have one, but its all in japanese, so I wouldnt have a clue!!
https://www.sau.com.au/forums/topic/209759-100k-service/#findComment-3721421
So you know better than the manufacturer?
What do you base this on?
Do you understand WHY Nissan recommends replacing the timing belt?
Your whole post is pretty stupid - you dont know how to read a timing belt sticker, which isnt rocket science, you dont understand why Nissan recommends the timing belt be replaced after 6 years, which is because heat effects the rubber of which the timing belt is made, and it gets weaker after it is exposed to heat
And who on this gods earth will only drive 5,000km in 6 years? Even my grandma does more than that
Really, its better to not post at all and let people think you are stupid than to make a post that removes all doubt
It bloody annoys me how many people will spruke on as if they are experts when really they just dont have a bloody clue
Replacing a timing belt is alot cheaper than replacing an engine
https://www.sau.com.au/forums/topic/209759-100k-service/#findComment-3721635
Yeah, thanx for that. Someone work up on the wrong side of the bed today, didnt they? Who said I knew better than Nissan? Of course I dont. I'm just saying, some cars are rarely driven. Rare cars, collector vehicles, that sort of thing. BTW, I know how to read a timing sticker, i'm a f*cking mechanic. I dont know how to read Japanese, thats the thing.
You do have a point with the heat thing, and I agree that this will affect it. I do stand corrected, but next time don't blast someone's head off cos you think you know better.
https://www.sau.com.au/forums/topic/209759-100k-service/#findComment-3722429
... i'm a f*cking mechanic. ... You do have a point with the heat thing, and I agree that this will affect it. I do stand corrected, but next time don't blast someone's head off cos you think you know better.
your a mechanic and you forgot about the 'heat thing'? dude, that's scary
I get cranky when people pass on dis-information which could potentially be very, very costly to others, thus why my post was a bit aggressive
rule number one of owning a car NEVER scrimp on servicing - I am very suprised that any mechanic would forget that, none of the mechs I have worked with ever have - seen too many cars stuffed because the owners wanted to save a few dollars in maintenance/servicing - happens too often
Too many people don't seem to get it that it costs more to run a car than just putting petrol in it - i.e. fix it before it breaks
sorry, starting to digress
Nick033, it has been too long since I have done a timing belt to remember what was charged, as for parts can I recommend you get quotes on the parts (off forum traders) and give the mechanic doing the work the opportunity to compete on price - they dont make much on parts, but would probably appreciate a couple of extra $$$ and the chance to be competitive
Would recommend gates timing belts (repco, covs etc stock them), and ring CBC bearings for price on the idler and tensioner, might save a few $$ for no loss of quality over nissan parts
And if you are supplying your own bits, make sure you bring along some coolant of the SAME TYPE that you are currently running, or get them to do a radiator flush at the same time if you dont know what type it is (should always flush if you are changing coolant type, or replacing unkown type)
hope that helps
https://www.sau.com.au/forums/topic/209759-100k-service/#findComment-3722844
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
