There is an article in the latest HPI magazine about getting 11s in your skyline...it is claimed there that around 220rwkw or slightly more is all you need for a 11 sec pass...don't quote me on that though...but whats said in that article carries alot of truth...the rest of the car's setup is just as important...so aim for about that much power or slightly more and concentrate on other areas...and don't forget driver skill too...
https://www.sau.com.au/forums/topic/209779-turbo-for-time/#findComment-3713318
As stated in HPI No90 10 ways to an 11 second 1/4 time R33 GTST.
Stock coil overs, stock turbo, stock injectors, rising rate fuel pressure reg, a well tuned aftermarket EMS, fmic, 3-4" free flowing exhaust split dump, 1 bar boost, 15" Drag radial tyres inflated to 20 psi, strong single plate clutch, 1/4 tank of fuel.
Also remove any excess weight from your car like spare tyre, passenger seats, etc.
Sounds like a good recipe for 220 rwkw.
To get into the 11 second mark with these mods would also need some drag racing experience i would think. As also stated in the mag.
https://www.sau.com.au/forums/topic/209779-turbo-for-time/#findComment-3714806
Yeh the latest HPi has mainly how to get your skylines doing 11's! pretty good read. I was reading it all night. Geting slicks for your ride would be good to!!
Slicks..why bother, why would you go to a drag stip, run a 12, bolt your street rims back and only have a 13 second car all of the time. Although ' street ' rubber is a harder way of getting the times, atleast you can drive away from the drag strip after you've done a 12 second pass in a 12 second car. Don't always believe what you read in HPI too :domokun:
https://www.sau.com.au/forums/topic/209779-turbo-for-time/#findComment-3714821
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
