There is an article in the latest HPI magazine about getting 11s in your skyline...it is claimed there that around 220rwkw or slightly more is all you need for a 11 sec pass...don't quote me on that though...but whats said in that article carries alot of truth...the rest of the car's setup is just as important...so aim for about that much power or slightly more and concentrate on other areas...and don't forget driver skill too...
https://www.sau.com.au/forums/topic/209779-turbo-for-time/#findComment-3713318
As stated in HPI No90 10 ways to an 11 second 1/4 time R33 GTST.
Stock coil overs, stock turbo, stock injectors, rising rate fuel pressure reg, a well tuned aftermarket EMS, fmic, 3-4" free flowing exhaust split dump, 1 bar boost, 15" Drag radial tyres inflated to 20 psi, strong single plate clutch, 1/4 tank of fuel.
Also remove any excess weight from your car like spare tyre, passenger seats, etc.
Sounds like a good recipe for 220 rwkw.
To get into the 11 second mark with these mods would also need some drag racing experience i would think. As also stated in the mag.
https://www.sau.com.au/forums/topic/209779-turbo-for-time/#findComment-3714806
Yeh the latest HPi has mainly how to get your skylines doing 11's! pretty good read. I was reading it all night. Geting slicks for your ride would be good to!!
Slicks..why bother, why would you go to a drag stip, run a 12, bolt your street rims back and only have a 13 second car all of the time. Although ' street ' rubber is a harder way of getting the times, atleast you can drive away from the drag strip after you've done a 12 second pass in a 12 second car. Don't always believe what you read in HPI too :domokun:
https://www.sau.com.au/forums/topic/209779-turbo-for-time/#findComment-3714821
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
