Hi All.
I've recently been going through the process of researching tyre dimensions to try and keep my wheel radius consistant while i get new wheels. I'm going from 16x7" rims to 18x8.5"
I thought I'd post up a little explaination of how it all works for anyone else wondering.
Take my old tyre dimensions for example -
215x50x16 where:
215 is the tyre width (looking from the front or back of the car) and is measured in millimetres,
50 is the aspect ratio of the tyre as a percentage.. ie, the height of the tyre wall is 50% of the width in this case
and 16 is the size rim it fits, measured in inches (the hole of the tyre)
.. would have been so much easier if they just did it all in inches or millimetres.....
so in order to keep the overall wheel radius the same, the following is the equation to follow:
rim radius (half the rim size) + Width * Aspect ratio
ie in my situation:
currently : 8 inches (203 millimetres) + 215*0.50 = 310.5mm
I knew i wanted 235s, so all that was left was to find the correct aspect ratio
with 18" : 9 inches (229mm) + 235*0.40 = 327mm
: 9 inches (229mm) + 235*0.35 = 311mm
Thus the tyre size i'm installing is 235x35x18
- Steve
ps. You may ask "why is this important?" ... well keeping the wheel size correct keeps your speedo accurate as well as your odometer. Also accelleration is noticably different with different wheel sizes (especially in less powerfull cars)
I'm not 100% sure either, so if someone can correct me, please do
Edited by Wogan
https://www.sau.com.au/forums/topic/209993-understanding-tyre-dimensions/
Hi All.
Well researched, youre mostly right but the sums that you have done will not help you when you are changing brands of tyres as no one size is the same from brand to brand.
I work for Federal Tyres and it is my job to advise people of the right fitment for their vehicle.
Tyre sizes and overall diameters are only relevant within each brand and even then they are not an exact science.
For example - A 235 / 45 R17 in one brand might measure 643mm whereas in a competing brand the measurement may be between 645 - 650mm.
There are to many variables between manufacturers to be able to guarantee that you are getting the same overall diameter as your last set.
You might have to have a look at your maths again though because a 235 / 40 R18 is a lot bigger than 327mm - your looking at about 645mm for that size.
very good point bullet 32.
I am amazaed at the range of actual widths and diameters in tyres that are rated at the same size. eg a falken ze326 in 265/35/18 is at least 2 cm narrower than a dunlop dz02j in 265/35/18.
Only really makes a difference in a 4wd skyline I guess, but don't mix and match brands even in the same size
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
