well my goal was always 700hp at the wheels on pump gas. probably a bit of a stretch with the T04z. Might do it with the 1.00A/R exhaust housing.
But i'd be pretty happy with anything over 600.
Going on other setup somewhere in the low 600rwhp is probably achievable but with the stroker and large a/r turbine housing you'll probably do it on less boost than what others have used. I've seen a vq30det with a t04z on meth on an engine dyno max out with 750hp with boost starting to taper off late in the rev range which pretty much indicates the turbo was maxed out.
  • Replies 58
Looks the goods m8 welldone. My setup pretty close 2 yours just dont have the stroker crank & cams a little different ive got 280 tomei in mine plus i got lucky 2 get a N1 block. Have 2 compare dyno runs when both are finished lol. You running .81 or 1.00 housing first. :teehee:
Looks the goods m8 welldone. My setup pretty close 2 yours just dont have the stroker crank & cams a little different ive got 280 tomei in mine plus i got lucky 2 get a N1 block. Have 2 compare dyno runs when both are finished lol. You running .81 or 1.00 housing first. :whistling:
yeah mate i was following your build. was keen to see how it performed on the dyno. How is it going anyway, get that shim issue sorted yet?
Going to run the 0.81 first, most important result for me at the moment is how responsive it will be.
cheers
Paul
There are a couple of RB26's getting around oz making 650 at the wheels with the T04Z. I figure a bit more torque from the extra capacity and a few more revs should see it get close to 700.
Not sure if i want to hit it that hard thou.
Be more than happy just to be banned from the plex for running a 10. hehe
cheers
Paul
Yeah the head is off engine out something wrong with valve guides apparently they found a few shavings in head from guides so its back at the head shop valves had a couple of scuffs on them they havent told me if its exhaust or intake but most prob exhaust but keep ya posted.
bugger man, there's always something ay.
i guess it will be all worth it in the end but sometimes it seems there is no end.
Ya dead right cant win was going to have it back 2 weekends ago they run it on dyno with 14psi & it made 311kw with no timing or full tune this on run in tune. Reved it 2 6500 only so it sounds kinda promising.
Edited by blitzxtr
  • 2 months later...
Just a quick update.
Intercooler piping done, custom catch can, custom over flow and header tank.
Just wiring up the last of the electronic gadgets now. Should be starting up this week. Nervous times! lol.
Thats MAD!
How does the HKS T04Z go?
Whens the boost kick in and how much you running?
I have sat in a R33 GTR with a GReddy T88 and the thing is lagy till 6000rpm and then it flys.
Also noticed you got the one piece inlet plenum... You planning for drag races?
Edited by (00)SKYLINE(00)
Dunno how the T04Z goes yet. Last time of drove my car it have R34 GTR turbo's.
Planning to run 1.8 to 2 bar boost.
Yeah the Hypertune plenum and single throttle body is becoming a favourite for drag racers. I'm planning on doing abit but nothing serious.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
