Hi all,
I will be fitting a Greddy plenum to my 25 soon and im wondering how will i plumb the BOV back to the intake from the other side of the engine bay?
Do i just get a pipe made from the BOV running along the front of the motor to the intake?
I want to run the BOV on the pipe going into the plenum,im ditching the washer bottle so will be located around that spot.
Looking through some threads i came across this photo.Im assuming this pipe is going from a BOV to the intake.
Should i be doing something like this?
https://www.sau.com.au/forums/topic/210152-plumback-bov-plumbing/
I run that plenum as well...At first I made up a pipe that ran from the intake pipework just before the throttle body going across the front of the motor (like in the picture) but lower, back to the compressor intake pipework...It was 1 1/4" pipe and ran just behind the cooling fan...I then changed this...Now the BOV is connected to the pipe work running to the I/C on the intake side of the engine...Much less pipework...
In my opinion either way works fine, the only difference is, if the BOV is fitted to the hot side of the IC, when it opens it passes hotter air back into the intake...
BUT when running pipework across the front of the engine, the pipe work heats up anyway because it is just behind the radiator so it heats the intercooled air anyway...The air in the plumback pipe is static until the BOV opens and heats up to the pipework temperature...So you dont really win either way
I have been told to keep the BOV as close to the throttle body as possible.
My bov is mounted under the drivers side Guard and piped back under the car and back up behind the power steering pump.
I dont like the pipe going across the cam cover for looks and heat. Under the car the pipe is at least getting some ventilation.
Is that your engine bay?
Looks awesome - mega neat!
Probably because thats where the pressure comes and stops - but I don't think it would make any difference to were it is
Yeah understand that although the BOV protects the compressor so based on this you would put the BOV as close to the compressor as possible..plus the air is hotter at the compressor outlet and would flow through BOV easier...
I have seen BOVs fitted to I/C itself as well...
I am with you, I dont think it makes a lot of difference....
Yep agree with you there :D
Shouldn't make any difference
I think it's just a way of keeping the build up of pressure more even into the intake plenum. If it were further back in the pipe scheme it would allow it to spike just that little bit more.
I doubt it makes that much difference, but it probably would help the longevidy of the engine a little.
Why not use a gtr approach
+2 - under (or close to) the bottom of the IC.
BOV before or after; I don't think it makes much of a diff either. One could say, that if taken closer to the plenum, then you maintain a flow or slug of air, through the pipe work while BOV's open.
I ran mine between the turbo outlet and the intercooler and venting straight back into the intake pipe. I'll try to dig up a pic...
If you fit it closer to the throttle body you would theoretically have to refill the intercooler and piping with new air on each gearchange / venting of bov...
I think ill go underneath,but stay in the engine bay.I dont think it will be affected by heat as much when down low.
Thanks for all your input.Pics would be good if anyone has any.
EDIT: I forgot to add,the turbo will be in a highmount position.
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
    • That's one of the reasons I got that breed, they look weird, the other reasons are they small, they are very vocal, and run around like they are on crack, I didn't want a breed that just sits around, these two are like kids on red cordial  My daughter has one, and it's a laugh riot, constantly doing Parkour around the house, sits on her shoulder, plays catch, and constantly runs around the house taking turns chasing the dog around, her Bermese though, just lays around with constant bitch face, and just looks on in utter disgust at the cat and dog playing together
    • I'm getting PTSD flashbacks seeing that name again.  With my turbo swift, I got 1,500km of street use on a Jim Berry clutch before it exploded and took out my input shaft with it.
    • It always seems the uglier an animal is the more is costs
