That was me :D Are you often there?
BTW yours 70th editon looks nice. ;)
im always there
also, have you noticed the gravel used in the car park leaves dirty black marks on ur car? i gotta keep cleaning it! :O
LOL :bunny:
KingsCross man, KingsCross... not Melbourne...
Just like the famous KingsCross quote: tsk tsk boom boom! like that chic on TV...
LOL should read the whole thing properly first!!!
Not a v35 but today at work im parked behind a really old merc with the plates that i wanted!
CPV.035 in standard issue. I wonder if he would let them go..
Wont hurt to ask :(
I think I spoted xscape237 today @ ballarat rd 12:30-ish turning in from small st - sporting his 20" chromies...
Across from 7/11?? if so then yeah it was me. I didnt catch you tho!
p.s. they are machined silver, not chrome.. at least thats what i keep telling myself :P
So I couldn't find a V35 specific one, and seeing as you guys have your own little community... might as well start one.
Spotted a white 350GT coupe driving up to, chucking a U-ey outside my dad's apartment and then parking opposite North Strathfield station in Sydney NSW.
Oldish looking bloke with greying/black receding hair driving :P
Hey guys, im a new v35 owner and have already spent a pretty buck on mine kitting it out.Iv got the impul bodykit, stillen air intake, sub woofers etc.I was wondering, is there any cruises/ get togethers for v35 owners here in melbourne?
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
