- Silver V35 Coupe parked on Ballarat Road next to Footscray Park at around 10:30am
- White V35 Coupe chick driver (not sure if it was Marie or not) turning right from Hawke Street into Spencer Street at around 5:30pm
- Red V35 Coupe at the roundabout near VicRoads and the local court in Sunshine at around 6:15pm
Wasnt me I was stuck in traffic on the westgate at that time last night....!!! :down: .....but I wish it was me I WANT TO BE SPOTTED .... !
If the white V35 had standard plates, then it isnt her.
if my memory serves me she has custom plates
but woo
Thirty 5 spotted yesterday on the drive into work.
Thats right Josh !! :thumbsup:
Ah... Bad choice taking the westgate in peak hour. Yeah same I haven't been spotted before yet, maybe we're ninja stealthing around, hahaha! :)
Edited by 81gSKy
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
