FKNLOL
cunny funts
Dave, sexeh rims, I want! but with a black centre... you give me? :)
See you bastards next Thursday? Mine should be back on the blacktop by then, sans massive epic engine build...
Nah, doubtful, mine should be getting tuned then, the thursday after should be ok
good to see car is up and running... been reading alot about it.. nice rims and N1GTR hmmm not so nice rims... not what i expected to see on your car
They're not whats meant to be on there :banana:
They're temporary
Yup
So who is up for a meet up tonight :domokun:
Where from and to?
I have a 7am start tomorrow so depends where to and i may be able to come - although mines run in now :P
im having drinks at mine after skating... It's not planned but it always happens anyway...
if you're in the area, give me a bell :domokun:
Figure skating right? lol
My engine would be run in if i had to drive to your neck of the woods :P
Two issues i have with the car. The gearbox/engine sandwich not being installed means the heat from the engine transfers to the gearbox tunnel and then into the cabin. With no A/C yet, the cabin heats up very quickly.
The other is the gearbox itself. The syncros are buggered. Shifting into first at a set of lights sound like engaging a straight cut box, and if i downshift too fast into 4th it grinds. So i think a full box rebuild is on the cards after Powercruise.
Ill be heading out to Harry's Cafe at Liverpool at around 9ish.
My engine would be run in if i had to drive to your neck of the woods :domokun:
just watch the shift from 2nd to 3rd between turns 9 and 10. Thats where i broke mine last time at Powercruise.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
