car will do around 250km to a full tank
mods
front mount cooler
r34 gtr fuel pump
car runs 10psi
stock computer
what is my problem and what should be normal full economy for a r33 running ten psi ?
anyone think the gtr full pump is not needed and to take it out??
Edited by rich flavour
https://www.sau.com.au/forums/topic/210487-r33-bad-fuel-economy/
  • Replies 74
Posted Images
Well i dont flog it but i guess if i drive off boost it would be better but i dont always drive on boost so it should be better then what it is
there is something wrong i get 350-400km out of a tank with 251rwkw @ 16psi (i boost it abit too) with ebc turn off (runs around 9psi) i can get upto 400-450km out of a tank
get an ecu and tune it
or use a piggyback
what are the advantages off piggy backing the ecu sorry for the silly question but i dont really know that much still learning any way heres a example:
i have a automatic Rb25det four door, 3" exhaust all the way thru coughcough no cat,FMIC,huge K&N pod filter,CAI + DIY heat shield for pod,runnin 7psi,split fire coil pack's and some
other stuff.
with the IMPUL r33 automatic ecu so if i take this out and use microtech LT10s ecu instead i will lose my shift points for automatic and aircon etc something like that anyway
so if i piggy back it with standard impul ecu i will still retain aircon and that?
will it be better that standard? any more info would be great before i go ahed with it guess it will help my fuel econ stop it from runing rich my mechanic said its runnin rich because im
pushing the limit on the IMPUL R33 Automatic ECU because the car can breath so much more air because off the stage1 mods i have noticed that it does not like to go to 10 psi hits
R & R so i left it at 7psi no flat spots aka lag so if i piggy back the IMPUL ecu with the aftermarket ecu then i should be able to sort out my A/F ratios etc.?
If you dont Know off the impul ecu here's a site that will let you know what it does ==> ==>"ABOUT THE IMPUL ECU click me" <== <==
here's the the type off car i got my ecu off
(actually it was SAU member i bought it off lucky if you can find one off these here's the link : ==> ==>"THE CAR THE ECU CAME FROM click me" <== <==
Cheers
Allan.M
Have to agree with paul, it is his ecu. If the car was stock then maybe not, but the ecu he has is not the ecu for the mods he has, esp. front mount and 10psi [how'd you measure this]. I had the same probs, and swapped for a pfc. I reckon the pfc has paid for itself in fuel saved and also gave a much better cleaner power delivery.
Plus, is his ecu stock? In a lot of jap imports the ecu chips are swapped out for no speed limiter/richer fuel units.
Have you popped the cover on your ecu and had a look at the chip etc?
yeh well i havnt checked the ecu for a chip.where could i get a test down so they can single out my problem? also where is the best place to get a pfc or im thinking of running a computer that dont use a afm...
i get 250km~ to a tank and backfire like a motherbollockser, and all ive done is a catback exhaust!
I think its time to check my o2 sensor too, the plugs are relatively new and i just gapped them to .8 but popping didnt change at all.
your an idiot if your warming your car up for 10mins each morning..get in start it idle it for 30secs-1min then drive it just baby it until thermostat opens and yeah...
ive got after market ecu LINK and its got a shit tune and i barely see 180kms per $60 around town and 250kms on highway so think yourself lucky.
time for a decent tune from a brisbane workshop:)
idling doesnt use that much fuel, obviously a bit more from a cold start but not enough to effect your economy that much, unless you only drive very short trips between cold starts.
you dont need to warm your car up for that much anyway, let it idle for 20-30 secs to build up oil pressure then just drive it soft to warm up everything, gearbox diff etc, not just the motor
how does this solve his problem?
what is the point of tring to fix the problem, if you don't know what the problem is. the problem isn't his ecu. and saying it is, is complete bs...
hi michael
whilst i usually avoid cross forum member attacks etc but anyway - given his list of mods and typical fuel economy most GTST guys see
i still think that its his ECU at fault, no where its a case of it just needs a decent tune, a sensor is toast, someone's remapped it to homo settings, or he has a non-supported 02 snsor etc
it could be many many things, but overall one of the essential fucntions of the ECU is fuel injection control and part of that is 02 feedback, which in turn gives you decent fuel economy 300kms+ to a tank.
short of wierd things such as split fuel hoses, loose fuel pumps, wierd filling up tank procedures (ie: him saying a full tank is really 30 liters instead of 50) then i suspect the ECU and tune is the next likely culprit. the recommended action would be to remap it, piggyback it, or change the ecu. if he isnt prepared to do then its needs more debuggin work on the dyno and on the street with a wideband sensor, which just wastes time and $. and besides he will make more power & response with either a remap, piggyback or standalone anyway
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
