Was meee, saw ya 2 buddy and ur last second wave....i waved 2 hehehee had a feelin was u and nearly in the same place :)
yea, i live in that area :P and my parents owns that bottleshop on lower dandy:D
I'm confused as to what NZMO actually is. It's an R34 with badges say GTS-R.
WTH??
i bought my front bar off him llol. i remember when he was doing the stuff to his car. pretty sure its a GTT converted to look like a GTR making it a GTS-R or something like that
OIC... makes sense now. That's a pretty good conversion.
Yeah its a conversion(Top Secret GTR front bar and Z-Tune GTR Bonnet) front diffuser ready to go on , thanks for compliment,you took a nice photo of it, i used it for my desktop.
cheers,
David
spotted Nick gtstsedan in his undies outside his gfs house this morning
geez man, wear a ROBE
lol the chiks dig it :laugh:
Finally after five years i've been spotted. Nick it's actually dark blue, but green's cool too. I was getting some motul and bits and pieces. :thumbsup:
ahk
yeh i was to :laugh:
you from around the area?
CNBLOW at the keilor village pub (great pub)
Spotted you as well Paul, i was actually across the road at the park for a birthday. While i was there spotted a grey kitted 32 with black TE37 wheels? gees it was loud!!, it had a writing which said 73 on the windscreen, possibly from the drags? for some reason i think it was "Roy"'s car, but could be wrong
spotted a silver R33 GTR with a carbon hood and SAU stickers
also spotted a tuff R33 GTR with no wing on the great ocean road
went past a workshop that had a heap of GTRs, stageas, anything with an RB. the OH R34 gtr was there too
Edited by GTR-boy
sounds like OH Performance on McIntyre (sp?) rd in Sunshine
the purple one? thats a gtt with a rb26 its not a gtr
looks like they've taken over that nismo joint next door aswell...?
