I am soon to be changing the spark plugs in my RB25-30DET and read something somewhere about using conductive grease (electrical) underneath the coil packs where they make contact with the cradles and where cradles make contact with the head..The aim of this is to ensure that a strong ground or earth is made..To me this makes sense...
I also though of using it on the contact at the top of the plug BUT...if the grease melts or runs down the plug insulator,,,NOT GOOD
Does anyone use this grease and if so where do you get it from??
BTW the white grease that Jaycar sell is thermal conducting and not necessarily electrical conducting..
I have done a search and couldn't find much info at all. Apologies in advance if there is a thread already but I obviously couldn't find it....
https://www.sau.com.au/forums/topic/210763-conductive-grease-under-coil-packs/
fapidy fap, shlock shlock
Hey Paul, Its called non dialectic grease I believe. Chemtron make a battery grease IE. Its not just electrically conductive property, but its preventing surface oxidization ability, that ppl use it for. Ppl use almost any petroleum product (really, they shouldn't be) looking for the effect.
You only need a v.small amount between surfaces to fill micro pits in both surfaces (like heat sink compound) so there shouldn't be enough to run.
If your concerned about getting the best connection possible, spend some time with some quality OFC speaker cable, bag of ring terminals. Crimp then solder. Sand all contact points, use vas on the alloy (around, not between surface's) to prevent corrosion and ground every coil pack bolt to the block & head. You'd want a decent grounding kit (not a $100 jap one, just make it all up yourself) - might as well do it all properally ;)
my 2 cents
Edited by GeeTR
If your concerned about getting the best connection possible, spend some time with some quality OFC speaker cable, bag of ring terminals. Crimp then solder. Sand all contact points, use vas on the alloy (around, not between surface's) to prevent corrosion and ground every coil pack bolt to the block & head. You'd want a decent grounding kit (not a $100 jap one, just make it all up yourself) - might as well do it all properally :)
my 2 cents
Many many thanks for that...I knew there would be something...I might try and fabricate some sort of a grounding bar with the OFC cable soldered to it so it stays neat and tidy...
Any idea who retails that Chemtron battery grease?? I tried a couple of local Auto elecs whose only reply was....Huh??? They are still trying to work out all that new fangled EFI shit...
No worries man :no:
Haha no idea, tis why when i first mentioned it (In your screamer thread I think) I said the Japs seem to use it. V.rare in Oz.
I rem a discussion in a automotive audio forum, where people in the game say, its almost impossible to stop corrosion on battery terminals; I just clean mine often.
As for other interface points, i think instead of trying to get the bleeding edge best conductivity on a few connections, just go overboard, and have MULTIPLE "decent" connections / interfaces :)
If you find some of this shite, do shout out :)
That conductive paste is actually for heat transfer and not electrical conductivity. On older RB's, the grease/paste is put under the ignition module to help remove heat away from it via the heatsink (as the dizzy sits up and away from the block). On these motors, when the module gets hot the car will just cutout/stall while you are driving (should start when cooled). Doing this may kill your coilpacks prematurely as they're going to soak up that heat more efficienty/effectively now. Its the same paste used for computer ecu's. Ive seen it priced from 18$ a tube to 90$. I personally went to pick-a-part, pulled every ignition module (rendering every dizzy useless) and collected up all the grease
Geetr is right about the non-dielectric grease however thats a different paste alltogether. As he said its used to reduce oxidation of the battery (which is generally sped up by poor earths). Grab some cheap earth leads from supercheap and start connecting them up (to clean surfaces!)
Geetr is right about the…
GeeTR is right about everything he says... LoL :D
Your talking about heat sink compound and igniters or transistor unit; a solid state, high amperage switching device. As such, it produces an amount of heat, and will complain if it cant get rid of it. Instead of OEM sinking it to cam valley cover (which IS metal but ISN'T cool) to help with heat, people suspend them on longer threaded bolts, or bolt to the firewall to move stop heat going the other way, from cam cover -> igniter.
We are talking about the coilpacks, which aren't as sensitive to heat, but to a – GROUND. Having that good ground is paramount for a decent electrical field creation and collapse.
Even new leads will get dirty, as I'm not talking about a few mm of untreated lead post, but .001 of a mm.
To clarify…
To prevent corrosion people use almost any petroleum based grease on the terminals, much like filing the surface of galvanized steel before welding, and then spray with rust inhibitor (or just grey paint) after you've welded it… to stop that surface oxidization.
There's enough contact from post to lead clamp that conductivity isn't effected too much.
+1 on the above, is actually being able to find some of the grease that's specifically electrically conductive (in addition to it being a simple barrier to atmospheric oxygen)
Edited by GeeTR
What about your typical antiseize greases - coppercote, nickelcote, they have to be more conductive while offering some protection against corrosion, both these metals are used in the electrical industry as conductors, so mixed with grease should make them a viable and easily obtained item.
They may not have the conductive powers of dielectric grease, but you'd think they would be a viable substitute.
Have to do a search on the net and see if anyone has rated their condustivity properties?
  • 2 months later...
I wouldn't use a conductive grease, as it heats up it would be liable to create a partial circuit away from the circuit required. No matter how well you apply it.
I use senson electroguard http://www.senson.com.au/ grease for protecting contact areas in plugs and sockets, as well as covering terminals. Specifically for marine electronics and electrical equipment, but for anything that might be required to be better protected from corrosion interfering with the reliable of the joint. Great stuff for battery terminals as well.
james.
Edited by heller44
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
