  • Replies 1.9k
changed my mind. I'm going to man up and bring this down for the main game instead. it will probably mean i spend most of the day under the car, re-attaching the turbo each time the studs stretch/come loose but what the hell... someone has to play the cannon fodder role!
quick question - what's the format going to be? do you break us up into groups and have (for eg) 10 minute sessions each like a normal supersprint, or do you get a series of single attempts to set your time - ie out lap, timed lap, in lap?
Oh yes Harry..bring the Datto 1200!!!
This beast is one serious weapon. I have driven this car a couple of times over the years when the previous owner had it. For those that know wakefield, I did a 1.07.20 in it a couple of years ago on old R compounds. I know the car is much better now from when I last drove it.
I love this car.....go the Datto's
HAHAHA I think from memory Jas it was retreads and the trailer. Hang on a minute..I think you car was on the trailer!!!
I still love you Jas, and yes I will let you know when I have a day free for some GP tuition :)
Steve, I am hoping that you will not need the cage so as soon as I know I will let you know. From what I have been told so far you wont need one but I need to clarify that. Either way the class you want to run in next time will not require one :D
Awesome :)
I think its still got the same tyres now!
sheez Bozzy - so much for being an unkown quantity eh?
but that's still seconds off the pace of the Exige - and that's with you at Datsun's wheel! then factor in my fat untalented arse slowing the whole show down...
should probably be a question mark after cheap too...
Expensive Dato race car is cheap cheap Nissan race car. Expecially what is turning up for open class.
very true. its all relative.
have you had your Zed on the scales? I know you've got lots of power but that's still a very impressive time for a big car at a reasonably tight track like Wakefield.
Now that the wheels point straight all the time and it has some consitency in the camber curves it should be a fair bit faster and noticeably easier to drive. Particularly on the technical tracks. Hence why I reckon there's a good 5 seconds or so available at OP GP for a 1.13 maybe a 1.12, the 1.18 doesn't align well with the other times.
If John can coax that out of it on the day, I reckon it will be hard to beat. It's certainly the sort of times, given a dry track, that I expect will be needed to be in there with a chance.
Cheers
Gary
    • This is amazing. Love that you’re giving the boys an intro to cars and off the screens. They probably have an insta for the car and build posts on TikTok for their mates.
    • It is.  Your car works fine with the tank full. If you drive like a Nana it works fine.  You give it a boot full with half a fuel tank, you get surge.  It 100% is a fuel surge issue. Maybe have a look at installing a Hydramat if you don't want to install a surge tank.  https://www.holley.com/products/fuel_systems/hydramat/
    • Hanging out in Perth for a conference. Asked for a room with a view… got a view of Bustdown Festival   might stroll down and go say hi to Spotto and some of the hoonfluencers
    • It’s definitely just a problem with my car, as there’s bound to be plenty of 4-600hp cars out there running a factory tank with an upgraded pump and or hanger
    • Ah right, that would be a nightmare as I only get 150ish kms before it starts having issues/half a tank, and yeah if I don’t get into it I could run it completely dry, it’s only when it comes into boost it will start to break up, it also does it in every gear which leads me to believe it isn’t fuel slosh/surge as 4th and 5th shouldn’t have enough power to cause an issue. It’s got me stumped 🙃
