  • Replies 1.9k
Yep Bozman aero mods coming along. We have been chopping up the side skirts and rear of the car making some real rack off side skirts and big rear diffuser. Sure to help, and designed with help of Carbon Artistry who has done our work for over 10 years and does lots of race car stuff. Also taken advice from an air craft engineer who is involved with the V8 Supercars.
We may not be the quickest on the day but will have the best aero of any car there and will look the part. Don't right us off either. We will definitely have the quickest zed there, he he.
Hey Jason I found another pic of your car.
Is that Kennedy? Please tell me you are going to superlap. Since Marcov can't make it you're the best chance I know of that could threaten Mark Berry.
hmm, I don't even think the berry/newman/hi octane GTR is the favourite. their time's only 2 sec faster than a full steel, full glass, 27mm restricted, crap tyred IPRA car :bunny:
Who's car would that be would be keen to check it out. Must be a bit of a weapon if its only that far behind with restrictors in place. As i would have thought that the Mark/Russ/Hi Octane car would have been the benchmark for track spec GTR's in oz as they seem to have the runs on the board. There are plenty of keyboard warriors out there but not to sure how many will back up there talk with times at the track ?. Should be an interesting event anyway sounds like there will be some tuff cars comeing out of the woodwork.
add to that Jeff and his crew at brandster have been developing 32 GTR race cars for years now and there is a lot of know how behind them. Fark, I've been in Jeffs garage at his work and there are enough GTR parts in there to sink a ship. many of them modified and/or developed or refined by those guys over the years. They have been one of the few real serious guys working at making a 32 GTR fast over race distance in the last 5 years. I would say Jeffs car with dave behind the wheel will be top 5 for sure and most likely top 3.
i fart in your general direction!
NO NO NO.
Lets get back to the car thing. Superlap to be exact.
I will re kick things along.
Zeds smack GTR.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
