  • Replies 745
Jus thought I'd let anyone know that the Motokhana in the K-Mart car park in Gladstone is on this Sunday starting from about 9 or 10 am. If anyone wants to come down, let me know. Otherwise enjoy your cruise dudes. It's sounds like it's going to be really good.
It would be awsome to change the cruise from Yeppoon to Gladstone... would anyone be interested in going to Gladdy instead for this Motokhana... it would be interesting... although it is tuff finding enough fuel to get there and back...
tell me what you all think??
or does it stay as a beach run??
Rick do you reckon you could organise the beach boys for a cruise to Gladrock??
Hmm... I really have to do something about my info on www.garagespank.tk
it's just that the plans for it are nothing like what I was going to do to it a couple of months ago... Although atleast it does have a T28 on it... to bad it isn't a S15 turbo... but it still a big upgrade from the CA turbo that was on it...
Actually is anyone interested in rising rate fuel pressure regulators... I want to order in a batch of these AMOS ones... cheap... different... did I mention cheap...
It's just they come from America so if anyone is interested in this great product... pm me or something just cause I want to order in one for myself and one for Phill's GQ patrol... so while I'm at it... should order in bulk... I'll try to get a price put up on that spank website soon... just so if anyone wants one of these cheap regulators they can call me... either that or they can order them in themselves of course...
the trouble with silvias is their independent front end, they just dont have the articulation or cross up. dont get me wrong, there great on road, but its was the wombat holes in the latest "tuff import challenge" where they come unstuck. but i dont know maybe someone out there has bombed one up with a 24in lift and possibly 38in tyres(not rims). but like i said, i just dont know.
Yeah Brocky Cutter I have done extensive modifications to mine and I still lift a wheel going over a gutter... they just don't seem to have the flex of a full bombed "floating"front end skyline...
although silvias always beat them in the uphill climb... It's a tuff decision but air lockers fix the flex problem...
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
