  • Replies 745
Originally posted by digsy_20
Actually at least I did that commodore over... crappy VL turbos... Although apparently that is a nice one... I even had time to pull the clutch in and grab some more revs to race him... that is almost ashame... but that is what you get for owning a barge that doesn't have a V8
Thats a change, bout time you got to see something more than a turbo badge ..... would get boring after a while. :)
I don't know about that dude in the GTiR though... I promise you I didn't rev my motor and he still did a limiter launch... silly boy you should know that if I don't race there is something wrong cause I will race anything that moves if the cops ain't around... oh well expensive lesson I suppose...
Wasn't a limter launch .... bout 2 grand from it actually, he wasn't racing you. He didn't even know you were there, he was toying with Saity ........
