Originally posted by digsy_20
Actually Matt I beg to differ... he did not even rev his motor until I pulled up and he looked at me... then he started Rev'n his motor... but yeah... other than the fact that he looked right at me he wouldn't have even known I was there...
dude I know him, he doesn;t even know who you are ..... believe me he didn't do it for you ...... but then again your right and I'm wrong ..... I yet again I can't have an opinion and you know all ...
  • Replies 745
Actually it would be interesting to see the Tone race the GTiR too...
Don't get me wrong I don't know the guy and I am not trying to pick on him but he is just a good place to set Tones Goals on the street because a 13 second 4WD is super fast on the street... (although I guess a 12 second 4WD is better eh Rick)
Would be pretty awsome to have a 2WD that quick... It would require heads more HP... look at Big Bill with his XD 12.4 at 118 MPH... that is 500 HP and Rick beats Bills street time with only 108 mph... but that is the Joys of new 4WD toys... you got traction so you don't need as much HP
how do people drive 12 second front drives... CRAZY!!
hmm 13 second gtir vs 12 second gtr .... :confused: I can already forsee the outcome .....
Originally posted by Low Vc in da house
What like the turbo badge on the back of your VL, your right it would be pretty boring have to go that slow as to stay behind you. :bahaha:
lol ...... yeah I'm starting to get sick of festiva's chopping me :) ... I only had a turbo badge for 1 day too ...... some little bogan stole it the day i bought the car .....
What time are we going to meet up on saturday and are we trailering the mazda down? Hey rick how much rooting around would it take to shift my torquesplit gauge from the dash cluster down to above the stereo. cause i could swap it for the oil temp gauge, just sick of nearly crashing when i watch the torque split which is pretty much the whole time i'm driving.
So who is racing this weekend? wish Shauno could race, I wanna see his car into the 13s as he had so much bad luck last time. Will be good to see the 2 preludes go head to head too and see if vtec will live up to its name. Will be awesome to watch the two gtrs go too. Looking foward to this weekend quite a bit now ..... Wish i could race though, ah well can't race every T&T while your trying to modify a car.
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
