  • Replies 745
No, still waiting on the headers, these things take time and money, I not know what I am wanting to do first, the car is like a two year plan I hope by the end of two years it will be finish to a point I am happy, have to higher stand then again that has always been me with things I buy.
The exhaust project fully finish is like $1,500.00 around about. so getting done in stages. Apart from that I am buying up speaker compoents at the moment, like I have already spent about $1,500.00 at Rocky Car Sound with only a headunit and alarm plus more gear being held for me.
Originally posted by Sciby
Dude, relax. It's all good. First time out there, no one's expecting a record-breaking pass. :cheers:
And those stats are never really accurate... my gts should be about to break 14s, (I hope) and you're faster than I am.
sciby if you don't do 14s I will eat my hat. Hell i did a 15 flat when my car was stock and running. I managed a very average 14 with more engine issues than you can poke a stick at .... you should creep into the 13s ..... well I think anyway ..... Dev relax you'll do a 13 .... but 12s are more likely ....
Originally posted by Bling_Bling
Who cares it just all fun that whole idea hey.
We will, its just fun to try and guess what times a car will do. althouhg last time i had quite a few people tell me that i would do a 13 without adoubt but I never ended up doing one so it was a bit disappointing ......... hmm I better shutup now don't want to have some be disappointed in their car .... anyway guys a 13 second street car is still damn fast and would beat the majority of cars on the street .....
Originally posted by Nissan = Good
Sames. It would be cool if everyone could just mellow. Anyway How am i going to mount this camera in the car on saturday and not get in the shit?
Very easily, the people at the drags dont seem to mind, we have strapped camera's in loads of peoples cars, from DC's to Big bills falcon. Just make sure it is in tight, both times we have just dodgied it up and used the camera strap as the support.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
