  • Replies 163
Posted Images
I'll be there on the 23rd March for the grand prix circuit!
There is another grand prix circuit practice day on Tuesday the 1st of April!
All you people working on Sunday come to this one.
Edge - I could try and swap my days and head out on the tues....maybe...
I'll keep you updated :)
I'll see how the car goes this sat...might need new pads...among other things :P
Actually - looking at it now theres a good chance my car will need a break! :D
we'll see though!
20th North Circuit
23rd Grand Prix Circuit
25th South Circuit
31st North Circuit
April
1st Grand Prix Circuit
Must have at least a Cams level 2 Speed Licence
Cost is $130
Starts at 9.30am till 4.30pm
"Must have at least a Cams level 2 Speed Licence"... that sounds bad (for me).
Sorry for the question - but how does one get a level 2 licence, particularly by the 31st?
I don't think I'll like the answer... :D
I'd really like to do Oran park before I move interstate in mid-April.
Easy as, its just a form you send off and a small fee :)
PM me if you want help with it
Easy as, its just a form you send off and a small fee :down:
Thanks Steve-O, I might take you up on that :P
I'm just having a quick look at the form and it seems you need to be in a 'Cams affliliated car club'.
That'd my first hurdle, I think :P
Cheers
Guess who's one of those clubs? :P
Really? Heh... I did think of SAU but thought nah... :down:
Anyway I'll go through the form fully tommorrow when I'm more coherant and if I get stuck I'll call for help.
Goodnight :P
Edited by Wayne_J
heading out for the 1st Duncan??
Ill have the GTR brakes done by then so might take both cars for a thrash and spend some time to get the bias and suspension working together again.
I want you to take my thing for a spin and give your oppinion.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
