Hi Guys
Decided to sell my GTR now and selling some of the aftermarket bits that i havent put on the car n some that i will be taking out n make some money back.
May strip my whole car n turn it back to standard so keep your eyes out for any other additional parts.
Located in Sydney
Some parts are New and some have little use in them.
Greddy plenum polished - $700 used sold
HKS CDI twin power with Harness plug n play - $480 used less than 5k
Samco heater hoses 5 pieces - $280 new
R33 GTR TPS used - $80
Carbon fibre valley cover Rb26dett used only for minimal time $150
Nismo clutch pedal with slave cylinder new - $140
Carbon fibre Grill - $200 - sold
Nismo braided clutch like - $80 used less than a week
https://www.sau.com.au/forums/topic/211091-r32-gtr-parts/
is the cf grill the one that you had to modify to fit? if it fits fine i am interested in it
No modifications had to be done i just made it more stronger by fibre glassing the corners and middle section.
ill add a pic of it on my car
https://www.sau.com.au/forums/topic/211091-r32-gtr-parts/#findComment-3733411
does the HKS twin power replace the standard igniter?
cheers
Hi
No it doesnt still use the ignitor the Harness which i bought n will come with it,
basically replaces existing plugs (harness) that go into the ignitor and is redirected to the CDI box.
pm's replied back
Carbon grill sold pending payment also maybe samco hoses
https://www.sau.com.au/forums/topic/211091-r32-gtr-parts/#findComment-3736487
grille sold pending payment
just added Turbos-Trust 618z's not much use on them about 20k done..want to sell these for $3000 slighty neg or if someone has smaller turbos to swap eg 2530's or GT'ss
also have DRIFT bucket seat wtih carbon back adjustable brand new never used - $400
https://www.sau.com.au/forums/topic/211091-r32-gtr-parts/#findComment-3743374
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
