Hey slow down! I wants to talk to you!
Give us three hundred pretzels.
Marge:You see? A little persistence and patience paid off! That'll be three hundred dollars.
Hey I don't think so. I got me three hundred coupons.
Marge: I should've said "Limit: one per customer."
Should'a but didn't so hand 'em over. Hey! Kids! We're eatin' dinner tonight!
Tiffany, Heather, Cody, Dylan, Dermott, Jordan, Taylor, Brittany, Wesley, Rumer, Scout, Cassidy, Zoe, Chloe, Max, Hunter, Kendall, Kaitlin, Noah, Sasha, Morgan, Kira, Ian, Lauren, Q-Bert and Phil
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
