I just machined my r33 gtst rotors and now the front end is clucking under brakes.
I dont think i pushed the calliper pistons in at all or if much.
It only happens under braking, even under light braking.
I removed the ABS fuse and it still does it.
I need urgent help.
PLEASE
Jake
https://www.sau.com.au/forums/topic/211418-r33-brake-prob-need-urgent-advise/
So you had the pads re faced???
Ive never heard of that happening before outside of race teams...
I bet you one of the pads is out, cause what you have described is what happens when you get old pads on new discs...
or new pads on old warped and very well used discs...
It causes a vibration and sometimes a clicking noise...
Id be checking the pads are true...
Apart from that the only other thing that can make a click or clunk noise is a loose bolt/fitting/pad...
Check the pads, re-bleed the system make sure there i no air in the lines and tripple check all bolts etc...
Also visually inspect the discs and see where the wear marks are on th disc, that will be a good indication of if my hunch is right...
Who machined your rotors....
Recently had same problem with xr6 rotors renouned for warping. Ensure your rotors have been machined properly and pay a little extra for new pads, save the headaches!
Sounds like the pads moving a little as well. I'll need to know exactly what sound it makes though. Does it clunk once? Click rapidly? Heavy or light application make a difference? Does it pull to either side through the wheel?
There is no evidence anywhere that using old pads on a freshly machined or brand new disc is any concern unless the pads are crumbling badly. In fact, the best bed in of a new rotor or surface is done with old pads. You can use new but it takes longer and can be unsuccessful. Did you do a bed in properly yet as well?
Also, I don't use shims in my brakes at all, and rarely ever get squealing.
Did you do any other work? Like replacing the caster rods? If they aren't very tight they will slide a little and clunk under brakes.
Found the problem,
Tried new pads, at first if appeared fine but only worked till the bed in material had worn off.
Another set of rotors and a machine when i was in Brisbane.
Lathe must have had slight "run out' or an incorrect dye was used, which caused the issue.
Thanks
for the advise.
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
