I just machined my r33 gtst rotors and now the front end is clucking under brakes.
I dont think i pushed the calliper pistons in at all or if much.
It only happens under braking, even under light braking.
I removed the ABS fuse and it still does it.
I need urgent help.
PLEASE
Jake
https://www.sau.com.au/forums/topic/211418-r33-brake-prob-need-urgent-advise/
So you had the pads re faced???
Ive never heard of that happening before outside of race teams...
I bet you one of the pads is out, cause what you have described is what happens when you get old pads on new discs...
or new pads on old warped and very well used discs...
It causes a vibration and sometimes a clicking noise...
Id be checking the pads are true...
Apart from that the only other thing that can make a click or clunk noise is a loose bolt/fitting/pad...
Check the pads, re-bleed the system make sure there i no air in the lines and tripple check all bolts etc...
Also visually inspect the discs and see where the wear marks are on th disc, that will be a good indication of if my hunch is right...
Who machined your rotors....
Recently had same problem with xr6 rotors renouned for warping. Ensure your rotors have been machined properly and pay a little extra for new pads, save the headaches!
Sounds like the pads moving a little as well. I'll need to know exactly what sound it makes though. Does it clunk once? Click rapidly? Heavy or light application make a difference? Does it pull to either side through the wheel?
There is no evidence anywhere that using old pads on a freshly machined or brand new disc is any concern unless the pads are crumbling badly. In fact, the best bed in of a new rotor or surface is done with old pads. You can use new but it takes longer and can be unsuccessful. Did you do a bed in properly yet as well?
Also, I don't use shims in my brakes at all, and rarely ever get squealing.
Did you do any other work? Like replacing the caster rods? If they aren't very tight they will slide a little and clunk under brakes.
Found the problem,
Tried new pads, at first if appeared fine but only worked till the bed in material had worn off.
Another set of rotors and a machine when i was in Brisbane.
Lathe must have had slight "run out' or an incorrect dye was used, which caused the issue.
Thanks
for the advise.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
