Does removing the hicas on a gts4 affect the 4wd system at all?
I was about to install my lockbar when I was given some information from a mechanic that it may interfere with the 4wd operation. Something on the lines of; the hicas operation being taken into account when calculating the amount of torque to transfer.
I thought the only method for this was comparing the front to rear sensors.
Anyone know the dealio?
https://www.sau.com.au/forums/topic/211531-gts4-hicas-removal/
Hicas removal won't kill your 4wd unless you do things like removing wheel speed transducers / wiring / etc.
What you may end up with if it isn't done correctly is quite heavy power steering effort.
Search for info on gtr's removal process and problems that occur as the gts4 and gtr are the same.
100's on here have removed their's, non have affected ATESSA that I’ve read about.
Some have heavy steering.
- SydneyKid says that a small change of castor (?) offsets the heavier steering.
- Someone on here modified the PS rack solenoid with a solid flange, to make it permanently light.
- The Tomei kit has a box you splice in, (along with the locking shims) that stops the dash HICAS light from turning on, plus giving factory like PS assist control.
I slapped a lock bar on, removed everything but have yet to drive it. I want to keep proper PS assist on my modern (modern'ish lol) import, so I figure I'll just splice the Tomei black box in if its an issue ($100)
My cents
I'd place bets that the tomei box is just a load simulator so that the hicas module doesn't see the difference. If I wanted to rip mine out, which is a long way down my list of priorities first of which is getting it moving again, I think it would be quite easy to replicate.
You can also wire the soenoid to a constant 12v, as long as it doesn't burn out it will give you permanent light steering, probably not what you want at 100+ though. Easier to build a pwm solenoid controller with a dial on it so that you can adjust steering weight for your wants.
I've only experienced the heavy steering problem when the
car had HICAS ECU problems.
From what I understand you can bypass the HICAS solenoid
in engine bay that sends fluid to the rear of car. This
supposedly bypasses the part that can cause the steering
to go heavy.
Also from what I remember there is a tutorial on SAU forums
about how to bypass the HICAS solenoid in the engine bay.
Edited by SKYPER
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
