After selling my car after Sydney Auto salon final Battle I was a little undecided as to what to buy next. Not being able to make up my mind i bought a 2000 IS200 then proceeded to lower it 4 inches and put 20's on it. Car looked the goods but had no power at all.
After thinking for a while I have now bought a 2004 V35 Skyline. Car has around 15,000kms on it and is a premium with sunroof and Bose stereo. I am looking to take this car in another direction, although show / street is nice I want the Skyline to be a classy cruiser. Think I will leave the interior basically standard (few touches here and there) and just upgrade the stereo. Bigger wheels and lower it slightley.
Couldn't help myself, car is now at Prime Garage in Japan having a Trust exhaust fitted. This will give it a great note but keep it looking nice and stock.
Tell me what you guys think. Have already ordered a few little parts from the states such as clear lights, badges, infiniti scuff plates etc etc.
https://www.sau.com.au/forums/topic/211581-pictures-before-it-leaves/
thnking of eventually buying V35 4 door as a daily...what are you going to do about the stereo (stock) item..i know Jap ones do not have the entire FM band as the Aus sold radios, also any fix on Jap Satellite Navigation. i remember tread long time ago on SAU, and the guy could not find a way to convert them to Aussie MAPs..other than simply to use the screen as a monitor.
keep us upto date with your details...........
all the standard stereo will eventually come out as i see it as to much stuffing around and $$$ to get it all working. At the end of the day you only end up with a stock stereo.
I believe Chris Rodgers on here can get it working but wont be cheap to have full function NAV.
Mine will all be replaced with aftermarket items.
I hope you realised that during compliance the exhaust fitted by prime garage in japan must be removed and replaced with standard item, so I hope it's not a waste of your time and money getting it done over there before compliance is done...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
