  • Replies 69
should be able to figure it out. Just do a search in here for the right thread (should be in the first three pages atually) and see what the minimum offset is. As loong as it doesnt sit in so much that it will fol on ur suspensin, then yes it will fit. THen its just a matter of having it hang out your guard.
depends on what your definition of "fitting" is...
will it sit within the guards, so that it is legal in Australia, no way in hell... my 17x9 +38 is close to flush, so a rim that sits 58mm further out would need about a 50mm flare to make it legal.
not in australia
dont care
and your full of shit
i got VIP friends in australia with the same fitment. never had a problem
unless you bothered to look, this is skylines AUSTRALIA
also, i never mentioned you would have problems, all i said was that it will not sit within stock guards, you would need a flare to LEGALLY conceal the wheel...
why don't you go play with you "VIP friends" seeing as nobody seemed to miss you when you were gone.
becuase it looks like im the only person pushing the boundaries of a stagea.
well me and like 2 or 3 others on here that i stay in touch with.
do me a favour and point me to an english stagea forum.....not in australia
...thanks
Good work Grant look`s good what`s the go with the guard`s dude have you had them rolled ??or are they stock ?,they don`t look stock do they hit any wear ???,what suspension set up are you running.Good to see your still got some work to do on the stagea,need some more photo`s of front wheel fitment ????,cheer`s grant keep up the good work,cheer`s chuckie
lotsa rolling
lotsa hammering the inner fender liner
lotsa pulling
lotsa sweat
wheel is like 3/4 of an inch from hitting hte shock
runnign 18k/16k custom setup
cusco sway bars
dmax adjustable arms all around.
way fun.
Good work You need to get some PHOTO`S so we can see what work you have done,gives us some idea`s on what`s what,& what can be fitted ,What rim`s are going on the Front ??,cheer`s chuckie,
nah
with a proper shock matching, its a decent ride
i mean, its stiff
but no worse than liek 10k 8k on an s chassis
its all in the total suspension tuning, not JUST spring rates.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
