Its A Hard Life Part 2
Guest INASNT
Originally posted by nismoR34
:D :D :(
that pic could be anywhere m8
:):D:(
here's one I just took for you - its my work site in the greek islands, I just popped over this morning for a quick dip mate ;)
firstly u is instant???
and u think i would be wearing a hard hat and ear muffs in a normal office?
wait i am gonna go put a nismor34 sign on the waterfall and take a pic of it just for u!
Jet
its not ***in cold here, the ac is on full all day everyday, its nearly 100% humid everyday
  • Replies 47
Jet
ok you may notice the little : p next to INSTANT, I wrote it as a pisstake cause thats what EVERYONE on here thinks your name is. I Dont! they do. I cant believe you missed that :rofl:
mate I must be one of the rare ppl who saw your plate and GOT IT first time :) again...
PS I have got a RED hard hat which I can put in the pic for you, this makes me an an Aerospace Engineer :)
Hope you are enjoying your time Denham
Guest INASNT
The only person that calls me INSTANT is that little indian chick in here!! :)
this aint true Denim, I have also seen countless other users including Makavelli call you INSTANT and you replied to him with
"Geez cant ANYONE get it right, one would deduce that to mean its a common occurence"
I can go and find these posts it if you like ?
hang on...
Guest INASNT
Originally posted by meggala
hahaha even denhams co workers have to shut off from his talking
note the ear muffs :D
your a bastard I would love to be there
those ear muffs are mine man :P
yes its a preety good place to work, pity about the north queensland people, they r farkin weirdos
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
