So, FRISKI is organising a group buy of stealth R33 wings and it will be heaps cheaper if we send all melb orders together. I am happy to organise this for ppl down here :)
Here is the thread:
http://www.skylinesaustralia.com/forums/sh...25&pagenumber=1
If you CBF reading it, they are the same as the UAS Stealth wing (or the one seen on the red JMS R33) and are $250 ea.
If we send them together we'll divide the cost of shipping ($120) between the number of ppl getting them.
As i understand it they come with all mounting bolts etc, and come with a gel coat (?) which i'm not sure if they require any work before fitting. Will keep this post updated.
https://www.sau.com.au/forums/topic/21209-melb-group-buy-r33-stealth-wing/
yes they require work to paint + fit to get rid of the gel coat.. i could probably arrange a group buy of paint + fitting at a mate's panel shop... anyone interested in that ? they're in cambelfield and are very good (they are fixing some other panle work that is required on my skyline soon
stop copying me, every1 loved big ricey wings...now i have a mad stealth wing, and james got one, now every1 is comin round..grrrrr
from my knowledge of things the order goes:
inasnt
a few others
you
now other people
:P
im not going down the stealth look path :D
Guest INASNT
inasnt
a few others
you
now other people
:D
yes u r right, i have had this wing for 2 years now, and soooo many people have asked me where i got it from and my answer has been :shake: !!
Fark there is already enough r33 around melbourne and now every1 is gonna have a wing like mine, farkkkkkkkkkkkkkkkkkkkkkkkk
dj lethal
i am gonna get worried if u get this wing, coz u have bought the exact same stuff as i have on my car.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
