  • Replies 72
im definitely in as i miss out on ahg day (damn c-red)
dale: ill pick you up to come along if you want you can play xbox on the drive if you want or just kick back and be deafened by the stereo let us know if interested
PM sent
*humps leg* :laugh:
Yes will definitely be happening. Just planning the map this week.
Will be a day run, probably meet at City West... 1pm Sunday 27th April.
I had an expo last weekend so that sucked up 3 days! (plus planning and moving out!!).
I'll keep you posted.... :D
Keep and eye out for Tweedle Dee and Tweedle Dumb as well if you could guys.......................
S'OK, we'll be going right past Heathcoate..... we'll watch out for them!! :laughing-smiley-014:
As luck would have it I BOOKED that weekend off today.... I'll be in esperance though, Perth is too far to drive for no other reason :thumbsup:
So feel free to swing by esperance on your way around burswood
so dale i take it the "events co-ordiantor" is letn you go then lol
Yep! I got full dispenastion from The Chief Of Domestic Policy, underwritten by She Who Must Be Obeyed :blink:
I will meet up with youse at the Burswood meet point.
I am really keen to attend but working until 11:00 a.m, so might have to see if I can catch up and tag onto the end or just meet up at the picnic! Very keen to meet other Stagea owners as I see so few around!
James :blink:
The weather forecast for Sunday isn't looking so good, with showers predicted.
This means that we may have to change the BBQ idea. I think that it would be good if we had a "Plan B" for this.
Does anyone know of anywhere that is sheltered that we could go. There is a cafe in the Synergy parkland, and I'm guessing that if it isn't really busy then maybe that'd do. Or maybe somewhere in Perth city.
Maybe we just play it by ear..... the weather guys are wrong a lot of the time!
I am not going to change anything other than the BBQ (maybe) so just come as you were, and we'll sort it out on the day, I guess.
The maps are finished, and so is the quiz.... I am planning some prizes, small ones for fun only (sorry no weekends away!). If anyone wants to donate a prize or get their work, or company do the same, then even better.
Feel free to put up ideas on this, please.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
