My car really struggles in the morning. I'll start her up and head slowly down the street, and at about 3000rpm she starts stuttering. When I got to the highway I couldn't get passed about 90km (in fifth gear) before she starts struggling. It is normal to be this bad? When she's warmed up she runs great, but these cold mornings worry me.
https://www.sau.com.au/forums/topic/212196-cold-starts/
I don't know if my ECU is stock or not. It seems there is another problem involved, it is only enhanced when the car is cold. I had the same problem a few weeks back where my muffler had imploded and we thought all the shit jammed in the muffler was restricting the airflow. Had the muffler replaced, car was running great, but now it's starting again. When totally warmed up (I took her for a long drive tonight) she starts choking at around 5-6 thousand rpm.
Before I had the muffler replaced I had my mechanic look it over, I don't think he did any serious inspection, but he definitely ran tests on all the electronics and said everything was fine. I guess I'll give him a call again tomorrow. Could it be that it was my front (is that what they're called) muffler is f**ked too, and that the shit we pulled out of the rear (steel mesh) was originally from the front, and now it's just building up again?
Thanks.
https://www.sau.com.au/forums/topic/212196-cold-starts/#findComment-3751882
lol.. Yeah.. Its a stock NA 6cyl. Its going to do that while your rev the chops off it.
Id say Reset the ECU first..
Then go see..
I have a rattle in my resonator box on my NISMO cat back.. does go away once the engine is warm (similar to what your experiencing) but it doesn't and shouldn't hinder performance..
P.S its not good to be driving your car hard when cold either..
https://www.sau.com.au/forums/topic/212196-cold-starts/#findComment-3752372
mine has a similar issue as well..
when i start it up after leaving it overnight or after more then 30minutes, its struggles to start unless i step on the accelerator to give it some help..
if i dont step on the accelerator, it just cracks, starts up for a split second and turns off
but if i just stopped driving, turn it off and start it again 5-10mins later it starts up fine, what could my issue be??
https://www.sau.com.au/forums/topic/212196-cold-starts/#findComment-3752565
I have the same issue. Advice would be good!
https://www.sau.com.au/forums/topic/212196-cold-starts/#findComment-3752741
I had a similar Issue after I did my RB20 to RB25 conversion..
This may not work on 33's and may not work on Stock NA's.. but I had something called a FPCM - fuel pump control modeul. I re-wired the circuit around ti so that it wasn't in use. I did it because I Had a look at the R32 Rb25DE fuel pump wiring diagram and then compaired this to the R32 Rb20DET and it was not present in the DE diagram.
Alturnatively.. Cheak AFM/reset ECU/TPS/Injectors.. theres a world of causes to "hard starts".. If you can get your hands ahold of a Nissan workshop manual it can help diagnose the problem
Edited by GTS4WD
https://www.sau.com.au/forums/topic/212196-cold-starts/#findComment-3753380
Then go see..
My rev limiter is at 7000rpm, I've gone beyond 6000rpm in the past with no trouble.
I don't drive hard when she's cold either, like I said the car struggles at only 3000rpm, that's about the point I normally change gears.
How do you reset the ECU anyway?
https://www.sau.com.au/forums/topic/212196-cold-starts/#findComment-3753616
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
