Hybrid Intercooler kit for R32, R33, R34 $1100 UPDATED!!!
  • Replies 101
Will this i/c kit fit a r32 gts4 just as easy? Please let me know because I am interested. Also, please let me know if it would be cheaper shipping to a Japanese address or an APO AP in Japan (base address).
Thanks,
Michael
Overdriver and NOZILR
the cooler will be avaliable in about 3 weeks time.
pm me your detail. I will contact you when the cooler is ready.
Goolf
780 for the cooler it self.
Nu2skylines
yes it will fit r32 not a prob
cant you come to australia to pick it up? =)
I prefer not to send them oversea. the postage will be alot more and insurance and heaps other things.
Can you get these intercoolers?
on the 21st you said it would be 2 weeks
on the 27th you said 3 weeks ??? (what the?)
Just bite the bullet and ask for poeple to confirm an order. This forum started over a month ago, if they havn't commited by now they are never going to.
Actually, we were planning a trip to Australia/New Zealand in October but I think I would have problems taking it back through customs but it would be cheaper than shipping it.
Is it really that much more to ship to a U.S. address or Japanese address? Man, Japan is not to far from Australia either but I understand all the taxes, insurance, and customs.
I've been looking around Japan but everything is so expensive. I think I'm just looking in the wrong places. I need to get to know some people. :uh-huh:
4door_Sleeper
I didnt mean to delay the groupbuy. its out of my control. I am simply passing on the messages from the supplier.
the pipe has been redesigned and ordered from oversea. the container has arrived australia but need to be cleared at the custom. it would take awhile. if you are in such a rush to get it I can get you the intercooler with steel pipe which is about 3 times heavier than the aluminium. please be patient if you want something better quality.
Nu2skylines
I always thought car parts are cheaper in japan.......
Does anyone know if fitting a brandname intercooler of similar size (eg GReddy R-SPL Type24 2 etc) requires the same level of cutting/pasting of bits on the front?
bless_you
thanx for your support man. I will pay the postage for you!
msg
you just need to msg me your details I will contact u when its ready.
OverDriver
about 70 bux I think. will confirm.
MM2death
I will let you know when the pipes are here.
msg me with your details and what would you like pls.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
