i bought a boss kit off GKtech, really good service and got hear quick to. but now ive installed it, i got the blinkers clicking back, but the steering wheel isnt.
its asif i have it on to tight or something, when i loosen it up, it starts to go back but not as quick as stock would, plus its on loose for it to do that. when its on tight, its also harder to turn.
anyone know whats it from? i really want to know, its worse then driving without powersteering, really annoying me. should i go get the pricey just jap ones? (dont wana spend another 100$ on useless mods)
cheers, issa.
Yeh, this is a common problem with Skylines and boss kits. Ur boss kit doesnt have HICAS, so the computer shuts it down, which is why it is so hard to turn. You can modify your new one with the old sensors, but its easier to buy a new one. I bought mine from a shop called MALZ, but I think Super Cheap sells it? If not, other shops should have them. The boss kits are made by HTB or something like that. Not sure exactly, but its close enough. Good luck!
i just took it for a drive, seemed much better, i did some of my own modifications. got electric tape under the sensors, enough so i could push down and it would stay up, then taped around them both (note thats why i put tape under so i could do so). taped around them so there stuck to the boss kit lol, im running no back plate on the boss kit, just the tape (acts like the back plate), but i still have the steering wheel not so tight. im thinking if i get the HKB ones, would it feel just like stock, or does it still have the same drama's?
cheers, issa.
*edit* thanks so much for the reply mate, really appreciate it.
Edited by phat_man
yea man, bought a HKB hicas one 2day from justjap for 99, its awesome, powersteering works perfectly, and doesnt seem like the steering wheel is on to tight when i tighten it up. the other one from gktech is hopeless for hicas, got the blinkers to click back but it was still crap. HKB hicas FTW.
now its awesome, just like stock but better wheel.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
