what would you charge for the rb30 stroker crank and rods?
you mentioned making forgies with it, but me and i notced a few others have gone the N/A path so just wondering if you were making non forged pistons to suit?
are you going to make these reguarly or made to order or just the 1 off batch?
any reason to why your not making this kit with a non forged piston? (not everyone wants to go the forced induction path)
can the kit be bought without the pistons?
whats the height difference between the normal rb30 piston and the piston for the 3.3?
i've been told there are pistons that have a shorter skirt that will suit the rb30de im building, cant remember the part number but what are the chances of them suiting?
do you balance the cranks?
will the 3.3 crank have knife edging or standard counter weights?
Shaun O - around the $6500 - 7000 mark with the AUS dollar at its current rate. It should see 7500 - 8000 plus rpm depending on setup.
Gerg R31 - The reason is that you are the only person who has mentioned it, so Im presuming demand is minimal especially due to the price involved. The other reason is that no one readily and easily makes cast pistons in short runs or one offs. I could easily make you a forged piston for an NA set up though. You would just have to spec the comp ratio you require. The length of the skirt has nothing to do with the comp ratio.
Edited by Spoolup
i just thought you may have designed pistons that were shorter to suit the stroker kit, if the over all height of the pistons dont change i might still be able to get the ones i had in mind, though i know forgies handle heat better
im aiming at around 10.5:1 to 11:1 comp ratio so if you made me a piston the rb25de piston dome with valve releif would be fine with me
plus i work at a machine shop so decking and other machine work and balancing etc is easily done
are you making the kit pistons dome with valve releif? flat top? or dish?
(i know alot of questions but more info may also bring more interest)
Edited by Gerg_R31
im sure that would be ok due to the lower rev range of the 30.
Well the rb26 in thier Z drag car is seeing 10,000 rpm with the tomei pump so i would think rob has something sorted...
Spool, so you 3.4L kits will rev to 7500-8000rpm?
We will have to wait and see - but similar setups with the 3.4L 2JZ ( near identical bore stroke ratio ) have gone 8000 plus easily enough
I have never had a RB26 in the 240z, its always been a RB30, stock block, stock crank, RIPS wet sump etc and anyone who says a stock 30 crank won't rev hard or is limited to 7500 etc is talking rubbish
http://nz.youtube.com/watch?v=nHLfRseF_F4
http://nz.youtube.com/watch?v=G6qtA0_kQUc
9500-10,000 rpm during burnout
Rob
Edited by R.I.P.S NZ
Rob
Bah you know i mean't. :P
Lol, clam down, its all good :) I was just correcting your 26 comment, nothing else in my post was directed at you.
I'm calm, its you rb30/26 thats the angry one. More nos, bigger injectors, more boost, less tit grabbing at the nats, and do some 7's :P
I'm calm, its you rb30/26 thats the angry one. More nos, bigger injectors, more boost, less tit grabbing at the nats, and do some 7's :happy:
Yes sir!! lol, I'll get all the non car stuff out of the way the night before, lol.
Next meet is this Saturday then another the following Sunday so I'll give it my best shot.
Rob
  • 1 month later...
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
