You can't really go pass RACEPACE and the way they tune our GTRs! This is from personal experience, alot of us. They don't have 4WD dyno because there was no need for one as GTRs can be tune@Rear Wheels.
How do you know he needs a GTR tuned? Am i missing something? He has a R32 GTS listed in his profile.
He may have a friend that needs a WRX or a GTIR or a GT-4, tuned.
https://www.sau.com.au/forums/topic/212630-remove/#findComment-3759208
