hi guys,
i did a search but could not find the answer - my brother has an r32 gtr with blown stock turbo's, been off the road for 4yrs!
i want to help him out & offer to pull the engine out of the car (with his help), he has a large garage & i can get an engine stand...i have pulled enignes out of other cars in the past on my own (i am mechanically minded) i.e. commodore, subaru, gemini, datsun 1600 & fj20turbo etc & that was quite easy.
i have heard different stories about the rb26dett though so i need advice on whether it is difficult or worth the heartache.
options 2 is taking the turbo's off whilst engine is in the car which looks very painful for access & room.
thanks,
https://www.sau.com.au/forums/topic/212663-replacing-turbos-on-r32-gtr/
hi guys,
thanks,
i do them engine in...much easier in the long run.
My friend done this for the first time on a R33 gtr last week, took him 4 hours off and 5 hours on, only took a bit longer as new manifolds were used and was difficult to get to the nuts that hold turbos to manifolds, and had to remove a compressor cover to get to them easily.
only tools i moded from memory 12mm open end spanner cut down for rear inside turbo flange on rear turbo and
rachet spanners will be good and lots of bandaids or 5 axis small ass hands and most important neighbours who not mind swear words
Edited by NIZ-26T
The ones I had trouble with are the manifold nuts directly behind the turbos under the manifold. Also ratchet ring spanners seem like a good idea in theory, but most times the head is too large to fit where it needs to be.. much like my hands.
Stubby ratchet ringies are your best friends when doing GTR turbos R+I.
Done it over three times now, just need access to top and bottom of the lhs of engine.
Remove front turbo and manifold first then the rear. Just look up the manual for instructions.
Takes about a day depending on lots of things lol.
If the turbos are blown, i would do a compression test before you do anything. Its fairly common when gtr turbos blow to take the motor with them.
do u think the bottom would have let go at the same time?
when u start the car it wont rev past 3000rpm - revs like an old datsun like its choking...no power at all
If the car has been sitting there for 4 years,
i'd pull the motor out for sure, and replace all the heater hoses etc etc around the engine..
tho its not sounding the best, perhaps leakdown, and compression test. and even take the head off to inspect?
car will happiliy rev with a blown turbo, it just wont make boost...sure you havent popped an intercooler hose off or something silly like that?
hi guys,
thanks,
I rebuilt my stock turbos with steel internals.
You Don't need to take out the engine to replace the turbos.
Just have to remove all the piping on top till you get to the turbos.
that actually sounds highly likely - that has happened on my previous car & the symptoms are identical
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
