Hey
Finished installing my GTR injectors and resistor pack onto my RB20 but the car won't start now
I have setup the Power FC as below, if its incorrect can someone please correct me
Old SIZE / New Size = Correction
260cc / 444cc = 58.558%
New Latency - Old Latency = Latency Correction
0.772msec - 0.89ms = -0.118
Then I went through the below options and entered the above values
There is definitely spark - checked that
The resistor pack has +12v running to it - checked that
I tried changing the fuel lines around thinking they may be incorrect - that resulted in the fuel pump barely priming and still no signs of the engine firing
Fuel lines hooked up the normal way - fuel pump primes as per normal but engine still doesn't sound like its going to fire
There is enough fuel as I drove it before I parked it - half way between E and 1/4 tank
Injectors were cleaned and flow tested prior to install and they came up perfect
Did a sensor check on the Power FC and everything seems normal as below
All the plugs are plugged in as they should be
I can't smell any fuel in the cylinder or see any fuel on the spark plug which is a bit of a worry
When I removed the fuel line there wasn't a great deal of fuel in the line - from memory the top had nothing and the bottom only had a little bit
When I crank the engine over the injector duty rises up to about 1.9% then slowly decreases down to about 0.4% as the engine keeps turning over
I'm really out of ideas now so any help would be much appreciated
:glare:
Yeah I'm not entirely convinced the fuel rail is holding sufficient pressure - I don't know if thats because the fuel is too low in the tank or there is a leak
I can't see any leak anywhere nor smell it and I don't see why the fuel would be too low all of a sudden but then again stupid things have been known to happen so tomorrow I will put another 5L of fuel in and try again
Fuel pump is a BOSCH 040 and I know it had a heap more pressure in the lines when I took the rail off to change the injectors, it pissed out a heap of fuel but now its just not doing the same
I may try and disconnect the lines and prime the pump then to see what happens
Yep running a Z32 AFM which is selected on the Power FC.
Thing is the car was running perfect before I stopped it to install the injectors thats why I'm not sure on what exactly has gone wrong
I just reread through your wiring diagram/install on GTR injectors and I have followed it exactly as its written - we removed the whole rail and part of the loom to hook up the resistor and I soldered each wire my self so I'm certain its right
Also double checked wires to resistor and they all seem correct
My INJ Corr on the PFC is still still to 1.000 as per normal - haven't touched that but the rest is (SETTING>INJECTOR) 58.55 and -0.12 from No.1 - No.6
Would really appreciate if you could check yours for me though, would be a great help
Question:
Does your RB20 making like a buzzing style noise when the ignition is on? Mines making this very faint buzzing noise which it wasn't doing before - is it the resistor pack?
Question:
buzzing sound would most likely be the cold start valve operating
youve definataly got the fuel lines into the rail the right way round?
cas plugged in?
battery at full voltage?? i know that it will still crank if its down some voltage but wont run.
ohh and also check the tps is plugged in. or hasnt been adjusted
Edited by AD4M
cas plugged in?
ah ok thats alright then - fkn buzzing noise is tripping me out almost like something is about to blow
Yep I was almost certain they were the right way then I thought I stuffed up so I tried them the other way but still no go!
From the fuel filter - does that fuel line go to the top inlet on the intake or the bottom?
Yep triple checked the CAS, even unplugged it and plugged it back in. All sensors are good according to Mr. PFC HC
EDIT: rechecked the fuel lines and they are all good, definitely plugged in the right way
from the filter into the line that isnt into the fuel reg, so into the line that returns to the back of the rail
Yep thats setup right then
Man I really don't know whats happened - could all 6 injectors have failed some how?
befor you pull the injectors out just check the tps is plugged in the right way, i run an ems so the power fc might be entirely diferent, but when i had mine in the wrong way the ecu was getting a reading of 100% throttle and wouldnt start as a safety built in.
worth a shot
worth a shot
Good idea man, I will have a look at that tomorrow as well
We only unplugged it so I'm sure the plug only goes in 1 way but just to be sure hey
have a look at THRO on ETC, SENSOR SW CHECK
it should be around 0.33v at idle with no throttle
From memory I think it was more abut .4xv but I'm not certain - will check it out tomorrow
How long between cleaning the Injectors and Installing them?
Resistor - If Installing the std injectors simply unplug the resistor and join all wires together - IE all wires have 12V
theres two plugs from memory, one on the casing of the tps, then theres one that is on a wire underneath it, you want the one on the wire.
Injectors were cleaned and flow tested Friday evening and installed Saturday evening so not long at all
ah yep thanks for that, makes sense now - worst case I will have to give that a shot
Thanks for that Adam - I will check it out this afternoon when I get back from work
Hopefully its nothing major :glare:
You dont have a plug anywhere in your wiring? Its less then ideal if its all hard wired, the last car i did i put additional plugs in it so that i can remove the ballast resistor and just plu the wires back together. I couldnt get a plug with the correct amount of pins so there were a few spare pins but meh.
I just realised I have no plug lol
I also couldn't find a plug with the correct amount of pins so I just cut the plug off and hard wired/soldered them all individually - I had no intention of ever removing the resistor pack anyways
Now I'll have to undersolder each wire...
This might sound stupid, but have you had you battery disconnected when changing them over? could just be a blown fuse?.
I feel for you man its an effort wiring and soldering in the injectors taping it all back up, putting everything back then not starting...heart breaking.
do you have a standard fpr?, cause if got an aftermarket one and you upped the pressure it needs to be turned down to run( well mind did).
hope you get it sorted.
I hard wired mine in... no problems.When are you going to change back to std injectors??
Hey Raz
Yeah man had the battery disconnected when changing them over but I will recheck all the fuses tonight just to make sure its not something little such as that
Yep was a pain in the ass man but we did it farely carefully and didn't rush - followed all the steps and insured that everything was connected correctly. We also took the top of the plenum off to allow more room so we could get it all done neatly so I had to buy new gaskets (throttle body and centre manifold) before we could put it all back together so I don't want to go ripping it all apart in a hurry if it can be avoided
Standard FPR - only fuel upgrades are GTR injectors and a BOSCH 040 which has been running with no issues for the last 5,000 odd kms
mmm I really don't know what else it could be
Prefer not to hook up standard injectors at this stage, if I was to try though it would be on the weekend
    • Hi guys, long time no post as per usual! It's been a busy year so far, the biggest thing being a new job.  After 28 years in the automotive industry I decided it was time for a change.  I was losing faith in the industry and where it's heading.  Now in a completely different industry (electrical) working for a company that manufacture water pump contollers.  Not as sexy as cars but it's an interesting,  challenging industry. I now don't work Saturdays which is a bonus!  It's still 50-55 hours a week but having Saturdays ack after 28 years of working them is awesome!   No news on the GT-R but i did decide to add some more JDM goodness into my life....           1990 300 ZX.  She's not perfect but for a 35 year old car she ain't bad!  Just going to tidy it up a bit and enjoy it.  It's currently auto but will start stockpiling everything for a manual swap. It WILL distract me even further from the GT-R but im hoping not for too long! It somewhat proves a 6'8" freak can fit in a 300 ZX.  Sort of...  I drove it home from the previous owners house in Melbourne via Black Spur and Merton Gap (2 awesome bits of Victorian twisty road) and it was amazing!  Handles so well!!!   I don't think it would be worthy of a full build page but I'll post up some of the upgrades here if anyone is interested?  Cheers guys!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
