  • 3 weeks later...
  • Replies 52
haha! success. after hrs of search, looky what i found!
http://www.skylinesaustralia.com/forums/in...t&p=2812191
apparently the dude is on gtr.co.uk and im off to see if i can find how he did it
be sure to come back soon with a DIY tutorial :thumbsup:
Yes some of the retrofits on that site are truly awesome. :thumbsup:
And yes some of the techniques seem dodgey particularly with the cutting of the actual backs of the assemblies.
Trying to reseal them etc.
Maybe you could make a prototype using the cut & shut and then glued together with bits of icecream container :(
Pour a mould and cast new ones.
  • 5 months later...
I have got myself a set of GTR Xenons i am trying to fint into my S1 GTST, I thought it was going to bolt straight up!!!
Clearly there is going to be some triming - it really hurts to cut the brackets off such an expensive pair of headlights
Can anyone help out with exactly how they did it?
Always fun to modify the modifications,
Cheers,
Dan
hey guys
bit off the subject but still headlights lol
my r33 has headlights with a chrome background in them
just wondering how many other people have them because all of the other 33's iv seen all have a black background
Isn't the chrome backing headlights off of the sedan or something? Could be wrong...
Those series 3 GTR lights with the angel eyes look great!
I'm so suprised after all of these years, with all the aftermarket headlights you can get for so many cars, that no one has made anything for R33's considering there is a f**k load of them. Hmm strange.
Edited by PM-R33
Thanks to [Michael] he gave me this website:
http://www.hkskylineclub.com/new/forum_pos...D=7466&PN=1
Not as easy as i had hoped but they look absolute porn!
That looks like a series 1 R33. Due to the bonnet design of a series 2 i dont think those GTR projector headlights fit.
Damn i wish i could get them to fit in my car.
Bit of topic, but how the hell did that dude on that site get the R34 centre dash display thing (i dunno what its called, that computer screen thing above the air con vents), onto his 33?!?!
I didn't know that could be done!!!
very easy,
he bought a MFD (or mdf cant remember what its called), cut a hold in his dash, wire it into his ecu and there you go its working
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
