Just installed my new RACE TRACK spec D2 coilovers on my nissan gts r33 98 model (only drive it on track days), took it down to the track and the car literally sticks to the ground, huge improvement for a reasonable price.
I found that the harder I adjusted the damping the more stable it got on corners. The Maserati behind me was all over the track going off the chicanes it was a laugh. But my car cuts off so given up after a few laps.
Rear: 3.0 turns from hard
Front: 2.5 turns from hard.
Will try harder settings next time.
https://www.sau.com.au/forums/topic/214339-d2-suspension/
Where is your local track. What other mods do you have and what tyres were you running? I only ask as i find peoples opinions on suspension vary greatly, so to me the real indicator of good suspension is the pace it can be hurried around a track. I drove a guys neat R32 GTSt at Eastern Creek a few years back. Had more power then my car, no speed limiter and about the same tyres. I have better brakes...and i was able to circulate almost two seconds quicker in my car then his....he jumped from mine wanting my suspension as whilst his was way firmner mine gripped a lot longer.
So what feels tight and grippy may not really give good traction, even though it may be to the owners liking or what he feels handles good. LOL hanflign does not equal traction :down:
https://www.sau.com.au/forums/topic/214339-d2-suspension/#findComment-3785857
ok well 1st off what were u running b4? of course it is gunna feel like the bomb if u've just been rollin round on stock suspension
again what tires, if there not the same as u ran on ur previous setup then u may need to factor that in
how did u change the geometry of the car (camber/toe/castor) also as its been mentioned dropping the car 100mm is gunna help feel and performance
also be carefull comparing to other cars on the track cause driver skill come into it ALOT more than the car, i've beaten 400hp GTR's around a track in my old car with 150hp and busted ass JIC's
also u list ur prefered settings for stiffness and say that u wanna try stiffer, were u being timed? and did u compare times to setting to find the optimum?
i dont doubt that ur car does indeed go better with these coilovers than ur std suspension... however these cheap coilovers D2's G4's and ISC's simply do not have the R&D put into them that they need. they use overly stiff valving and spring rates to make it 'feel' faster and more fun to drive, but infact if you push it to the limits they simply cant provide the grip that a quailty product can. i have custom bilstine coilovers all round on my car (track only) and i love them, they're softer than my previous jap spec coilovers but provide much better grip through both the tight twisty stuff and the long sweeping bends; admitadly it is too soft for drifting and as thats the direction that i wish to take the car they will have to be rebuilt to new specs, a costly and time consuming exercise, but necessary if u truly wish ur car to handle
basically what i'm saying is they're good, an improvement over std, but there is alot better out there and personally i wouldnt touch them (quality products will also last longer)
https://www.sau.com.au/forums/topic/214339-d2-suspension/#findComment-3785999
well gentlemen, let's not overcomplicate things.
R31_pwr how do u know that D2s don't have R&D put into them? :D
comeone fellas, we all know who the big players are and many people fall into the trap of paying the extra 1,000 bucks. there are people that bash teins, ohlins etc..I know a guy who suggested buying USD 20,000 suspension saying they were the best. By the way D2s are not cheap, I think they are reasonably priced rather haha..let's not get corporate...but anyway who knows I probably will try the others as time goes by and the track gets more serious. By the way we're doing trackdays in Dubai at the Dubai Autodrome.
Roy I think you were faster due to skills maybe, but let's not forget NA are generally lighter than the GTSt. Also luck plays a role as well as he may have slipped for a split second which accounts for the time difference.
I think my current Marshal KU17 92W R16 are ok but I might need to upgrade to steel re-inforced side walls. I am working on the car, have been for 4 months now and there always seem to be improvements to be made.
https://www.sau.com.au/forums/topic/214339-d2-suspension/#findComment-3786360
We swapped keys, he drove my car for a session and i drove his. We both agreed that my car was a little more dull but had more grip and the times it did showed. Hios car was tighter and dartier, but less grip and slower. Could have been tyres, alignment etc etc. So, meh, not sure how much water my point holds. Before after times etc always make a good indication rather then seat of pants :D
https://www.sau.com.au/forums/topic/214339-d2-suspension/#findComment-3786402
i didnt say that they didnt have R&D put into them (any new product has to) what i am saying is that its not suficent. also the build quality is poor, i have seen the mounting brackets (S13) snap in what could be deemed as a small incident (car got about 1 foot of air)
these coilovers are built in china on a tight budget and it shows, unfortunatly most people that would even consider fitting these to their car would think that they're the ducks nuts cause all of a suden its a stiff, jumpy and 'feels' exciting which 'feels' fast... it took me a while to learn that a boring ride/drive is often alot faster :D
https://www.sau.com.au/forums/topic/214339-d2-suspension/#findComment-3786509
  • 1 month later...
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
