look what arrived :down:
they're the optional "sport horns" that are supposedly both louder and meaner sounding than stock!
i know they say "Z" but they are for any VQ35-equipped car
..as any V35 owner would have found out by now almost anything is better than the stock horn!
i got these from eGay from a place in the USA. shipping took about 1-2 weeks not bad at all
i will install them tomorrow (if i can get home early enough). i'm thinking of running them in series with the stock horns for twice the horniness but not sure on that just as yet.. might see how they sound first. anyone else run 2 sets of horns before?
cheers,
Warren
EDIT: see post #8 for the install process and a sound file comparing old to new (.wav file, uses media player)
Edited by WazR32GTSt
https://www.sau.com.au/forums/topic/214343-got-horn/
They look awesome! Mine has twin air horns that stuck on the other day in peak hour traffic, quite embarassing, bloody issues! needless to say im not sure if they will ever work again after reafing at whatever i could grab hold of through the bumper to get it to shut up... haha
https://www.sau.com.au/forums/topic/214343-got-horn/#findComment-3787693
ok horns are installed.. :D
First, the install procedure.. took me 10mins max
picture 1:
tools required - 10mm ratchet, flat-head screwdriver
picture 2:
remove 6 plastic screw thingos that hold the front grill in place. to remove, simply lift the centre part up with the screwdriver and then the outer part comes out
picture 3:
once all 6 are removed, the grill can be held forward to give you a little more room. the grill does not need to come off
picture 4:
locate the horns (right in front of you)
picture 5:
to remove them, use the 10mm ratchet. its one bolt for each horn
now, take your new shiny sport horns and swap the connectors over between the horns. there's one plug in the centre and one on the outside
picture 6:
install the new horns by bolting them back into the stock location using the 10mm bolt you removed previously. the horns point down in the stock position so make sure you put them in the correct order
picture 7:
enjoy the bling of the new horns!
so how does it sound?
to be honest, not hugely different at first, but 2 things that i noticed were different
first, it is much louder than before
second, its more high-pitched than before
i have attached a before and after sound file for your information. this was recorded in the drivers seat with the drivers-side window down. taken out on the street so as not to deafen myself in my garage!
its hard to really appreciate the difference with the sound clip, but the new hown has lost the dullness of the old horn. the stock one, while low-pitched, seemed flat and a bit girlie. the new one, although higher pitched, is louder and more in your face.
enjoy!
cheers,
Warren
V35_stock_horn.WAV
V35_sport_horn.WAV
https://www.sau.com.au/forums/topic/214343-got-horn/#findComment-3788343
Excellent... the sports horn does sound higher and sportier, although I think Nissan initially put the lower note on the standard horn to make it sound like some big european car. At least if I closed my eyes and listen to the two sounds that's the impression I got with the sound of the stock horns.
https://www.sau.com.au/forums/topic/214343-got-horn/#findComment-3788931
my old horns can be had for $20 + delivery to anyone that wants them :bunny:
hello mate,
can i get your old horns off you?
i got this horrible squeaky thing that im embarassed to use :(
im in sydney, that alright for postage?
https://www.sau.com.au/forums/topic/214343-got-horn/#findComment-3789203
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
