my opinion of the R32 is: R32 with RB25DET > *
you got the style, looks and power out of a small comfortable car.
even the RB20 with stock internals, decent turbo, cams, injectors and computer will set you up nicely.
on the other hand, my opinion of the R33:
that is all. ;)
that's the best looking boat i've ever seen...
  • Replies 165
Posted Images
I know that if I were to have a daily I would definately want something with a decent interior so I would recommend an R33, possibly the Series II because they look much nicer on the outside than a stock series I. Just had mine tuned and pulled 270hp with pfc some more boost and basic mods and she goes quite well. 450km+ to a tank.
On the other hand if its great distances that you are travelling then 32 because they deserve to be run into the ground like a beat up VL haha
that is all. ;)
faster in the water than r32's are on land
/stir
Hanging is too good for R33 owners....and so continues the downward trend of this thread ;)
But to the original poster, just shop around and look at both models. Sooner or later you will find an example that you tick most boxes and will like. It could be an R32, could be an R33. There is no point comparing stock ones as there are more modified ones out there then stock
exact same mods to a 32 and 33, and the 32 is slower? geee, reallly?????! derrr! dont hav to be a fregin scientist to firgure that one out.
evryone knows stock for stock the 33 is faster...and if u mod them in the same way ofcouse the 33 will be faster..
my 32gtst has only a few minor mods (exhaust,fmic,11psi,ecu remap) and it will get to 100 in mid 5's on crappy rear tyres...
so u may hav to mod the 32 a lil more...pfft, who cares, atleast ur in a car that looks better than the thousands of boat 33's drivin around...i see them every single day...ugly as hell itself.
they dont even get a second look, 33's just blend into the b/ground like commodores.
if u want sumthin special a nice clean 32 is the way ;)
Can't believe the amount of morons ARGUING about the look of the 2 models...particularly you 32line
When will you get it through your thick heads that aesthetics are 100% opinion based and should not factor into a debate like this as its up to each individual as to which they prefer...
You can say R33's are ugly until your blue in the face, but no amount of dribbling can make that an indisputable fact.
As for everyone mentioning the weight of the R33 and how its such a 'boat', its always humerous to note that they never seem to mention that an R34 is heavier still.
Improved suspension, safety etc will all add to the weight...so while yo drive around in your 'super lightweight race car' the rest of us will drive around in our superior boats.
that was well said.. although i do agree on the interior.. my interior eats ass even thou its a GTR...
R33 = much better inside :thumbsup:
and another point.. 32line.. u want a special r32?? stop makin it look like something it aint.. its not a GTR. lose the wing, lose the front bar and skirts
want it special?? get something no1 has.
There is a few r32's out there now going for some pretty cheap prices too. Well under the 10k mark, and that's for turbo manual models.
Have owned both, with my first skyline being a series 2, r33. absolutely fantastic to drive, and literally nothing ever went wrong with it in the 1.5 years i owned it.
bought a r32 after that, and the differences are pretty noticable. the rb20det is pointless. the only way i could get the car to do sub 14 quarter miles is if i threw it off a cliff. the interior is a lot less comfortable, and a lot more noisy.
at the same time, the car handles ten times better, and i don't feel like i am about to plow into the country side when i take a sharp turn.
so now have put a rb25det into it, which makes the car fantastic to drive. noticably quicker than the r33, with the same ammount of mods. now i just gotta get some bigger brakes for it, as the r32 ones aren't up to scratch.
as for the interior and noise, i just drive with the music a bit louder :thumbsup: and will hopefully get some recaros by the end of the month.
R33 = much better inside :)
hahah, 32's look shit stock...33's look even worse. hence the gtr bits. btw...the skirts are the standard type M ones made for gtst :D
and dezz i am aware aesthetics are 100% opinion based, but i love to stir 33 owners in sh*t pointless threads like this one :D
32 FTW!
mwhahahahahahahahahaha!!!
I would compare RB25 to a similar capacity motor like RB26.
SR20, RB20 are more even, as they are in the same 2.0 litre class
and produce around the same peak hp (600-700hp) when modified.
Also look at what the RB20DET was competing against in the 80's
(Japan, Australia, UK).
That would be Honda Civic, Ford Cosworth, BMW M3, etc.
Edited by SKYPER
The gtr kit is the best looking and most functional kit you can get for the 32 gtst. Not everyone with a gtr kit wants a gtr, get over it
ps hows the blown motor going haha gtr's FTL
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
