  • Replies 44
Posted Images
Anyone done this themselves?
Just looking for some tips on getting the moulding right etc
Doesn't seem like a hard job, and I'm rather familiar with fibreglass, but knowing me I'll stuff something vitally important
and just like that, it became a group buy haha...
So is one st being made and then MOULDS now? seeing as so many peoplewant tem, is it worth getting them made by a body kit shop and paying that lil extra?
How familiar are you with FG, oddy? what do you think? Otherwise the pressures on you to make like 10 set haha
Ahah sudden group buy!
When I say I'm familiar with FG, it means I've used it before (made a parcel shelf, rolled guards on an ae86, basic frontage on sub box)
I was going to wait til I could buy some paint but pressure's on now, if only I could get days off from work
I might make a few sets at the outset (I dont have access to an S2 yet) and bog/prime them smooth and send em out for you to paint yourselves (if they come out good).
Having said all of this they might turn out dodgy as, but I'll likely post a step-by-step as I go so I can narrow down how it went.
Time frame at this stage will be a couple of weeks - I work 80 hours a week so I gotta wait for a day off
Slow your roll - I'll keep you updated!
give me some time and i might have a go, my old man used to do fibreglass boats for a living so he knows his way around fibreglass and making moulds. Ive made a cold air duct for the stock bumper before and than turned out great, im sure the eyelids wouldnt be that difficult, ill post more when i have a better look at the car and some spare time.
Check Howies topics, he made a tutorial with his R34 eyelids
Here's the linky for those interested.
http://www.skylinesaustralia.com/forums/R3...ml&hl=Howie
I was about to throw up another fibreglass repair diy article (repairing a front splitter using glass) soon.
meanwhile if anyone else wants to have a crack at making some eyelids too (someone with an S2?)
feel free.
It can't be THAT hard!
How much do eyelids retail for anyway?
From slidewize the one I linked before shipped to our doorsteps is 175 dollars via EMS, 160 via container. Then you need to put money aside to get them painted. It all adds up :D
From slidewize the one I linked before shipped to our doorsteps is 175 dollars via EMS, 160 via container. Then you need to put money aside to get them painted. It all adds up :banana:
Better off making them at that price! :D
not sure i haven't checked as i dont have a S1...
here is a link - click the seller's name and check for S1 maybe :) as he sells for all kinds of cars.
http://page15.auctions.yahoo.co.jp/jp/auct...treevillage1964
They are perfect!!! I want them - but the only prob is - that page is all Japanese and I have no clue on how to purchase or see how much shipping will be....
have you got a English translated link by any chance...??
Edited by FULOCK
you right click - and it should say 'translate this page to english' OR go to google, language tools, select japanese to english and paste the link.
OR alternatively i can source them for you and a price delivered
that worked :D now, 3000yen is approx $30 yeah??
whats this mean exactly: (Shipping nationwide uniform 630 yen (excluding Outlying Islands)
代引手数料 ¥525 Pulling handle 525 yen's fee)
is that the shipping costs.....??? pulling handle...??
how much would it all cost delivered to Melbourne??
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
