My tyres have come of age and are losing tread, so I figured I might get some cheap replacements. So I was browsing, and came across these:
http://www.tempetyres.com.au/products_clos...mp;part_no=1235
What do you reckon? Pictures of my R34 pearl white sedan are available in my profile page to help you visualise lol.
If NOT these... what style DO you think i should get?
https://www.sau.com.au/forums/topic/214917-about-to-buy/
Those style of wheels look great, but have you ever considered purchasing the genuine version of them? They're call Volk GT-C's. They'll cost you a little more, but you'll have better widths, offsets and quality wheel.
https://www.sau.com.au/forums/topic/214917-about-to-buy/#findComment-3795030
Well with lifetime structural warranty im not too fussed about the quality... but if i could get volks for a grand id be more than willing, but it seems Tempe Tyres dont stock volk's... plus im in sydney so i guess i cant ask u for somewhere that might sell em lol
https://www.sau.com.au/forums/topic/214917-about-to-buy/#findComment-3795044
Hmmm..
Personally..
Not a fan.. seen too many cars with these on them..
Wedssport TC105N, XD9's FTW!
Do it it right and get something light..
Mine and your tuning perspectives may be diffrent though. Im all about function over form.
https://www.sau.com.au/forums/topic/214917-about-to-buy/#findComment-3795169
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
