Good man! You end up using that redline I gave yoU?
Not yet, i'm not sure if there's enough (i think the diff takes 1.7L???) so i was going to get more and do the box and diff together :(
Too bad it won't make me as fast as your new setup :D
Hey Gary, we are installing the cams into my car in 2 weeks time, could you quickly describe what "shimming the standard springs" is and does? I've never heard of this and was wondering wether we should be doing this with my standard springs.
Thanks man.
the lifter bucket has a shim inserted in it to set the lifter to cam base circle clearance.
the shim sits between the top of the valve stem and lifter bucket and unless a spring has failed to the point it cannot properly close the valve shut, it (the spring) has zero determination on what shims are selected.
not sure what Gary/Sydneykid is on about
Edited by DiRTgarage
Oh ok, thanks for the reply man. Ill see if Gary replies and explains what he ment, hoping these cams go in nice and simple :P
$400 to install, fair enough.. Wont be grinding as they are direct drop in tomei items.
Nothing is a direct drop in.....
More than likely you will need to spend more
Your springs could need replacing....
http://www.nengun.com/tomei/valve-springs
Your shims may be out after measuring...each of these cost $30+..I know I needed 21
Luckily some where close and we only changed 17
And if your doing it right....you will also need these...
http://www.nengun.com/tomei/cam-bearing-cap-studs
Good luck
worn valve seats and/or valves may cause you to run a thinner shim than standard...but always check the clearance when changing camshafts even with the same base circle. Remember the intake will be different to the exhaust when using STD valves.
By shimming the spring, you fit a shim/washer at the bottom of the valve spring between it and the head. It increases seat pressure to reduce valve float/bounce, whilst maintaining the same cam/valve tip clearance. You just need to be careful to ensure that you dont go to thick which causes spring bind/fatigue.
It is used very commonly in the cylinder head repair industry, just need to be careful with the measurements.
You reckon any of this is needed if your not going over 9mm lift?
on low reving V8 dinosaur engines yes...but given the relatively cheap price of aftermarket springs and the high reving multi valve application this is a process id strongly advise against.
but everyone is entitled to their own ideas. :)
stock springs will be fine to use with 8.5mm lift if they pass a free length, pressure load and squareness test
cams dont sound fun any more :laugh: would there be a relation to age and replacing these parts? I dont think the stud bearing is needed as its only 8.15 lift from memory correct me if im wrong i forget
You will only know when you open it up...that's the only dis-advantage to after market cams.
As far as what they do when installed....that is quite obvious....you will be very happy when they are dialed in with a tune.
but everyone is entitled to their own ideas. :laugh:
My experience with building RB race engines (9 years and over 60 of them) is that all valve springs need shimming. Regardless what brand name is on them, they have minor differences in seat pressure, every head is different. Then you add in the differences in valve seat height accross individual heads and the variations in seating become more obvious. No spring manufacturer could possibly make a spring that is going to have the same seat pressure on every valve in every engine, so to do the job properly you need to shim their bases. We're not talking about thick shims here, less than 1 mm is common, occasionally 2 mm. Sometimes the reverse is required and we machine the spring bases in the head to decrease the seat pressure.
Obviously we aim for a higher level of precision on a race engine, but that doesn't mean the same process isn't followed for a road engine.
Cheers
Gary
Definately recommend tomei studs (per 700hpgtrs post) even for the straight fit cams, makes the install much easier with no risk of stripping the thread in the head when trying to pull the cam down. If the install is being done by a shop with plenty of experience I expect you can do without (but it is cheap insurance).
Edited by DCIEVE
Cheers
Gary
as i said...everyone has their own ideas...all the big revving RB race engines built in this country that ive been around and/or involved with (and ive been around a few) have never had this sort of modification...Yes Jap springs that are used in all these engines have always been spot on JUN Tomei etc....
and im talking about 1000hp+ engines revving over 10 000rpm...if they don't require it im bloody sure a street engine wont.
Does that 60 engines include the ones Harris' have built for you or the ones that never *********** and people demanded their ***** back on?
Ok thats good to hear, aslong as the springs are fine (which im hoping they will be) ill drop my cams in and hopefully not have to worry about the shims. Suddenly went from an easy job to a nightmare when uz started talking about $30 shims lol.
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
