if it's keeping the headlights clean then i use re-po polish! polish the crap off and then i start going over it with very fine sand paper! something like a 1200 or finer! and then i go over it again with polish! they still look pretty clean after half a year now!
i am getting my kit on the weekend......from another mate of mine who has a S1.....i always thought that the s2 lights would bolt up to s1 body.....ahh well and kahli what is the deal with putting your lights in the oven....
I think the idea with putting them in the oven is to soften the seals on them, so that you can open em up and get to the insides to polish the crud out...Or at least thats what i gathered from a guide i found somewhere on here...
I thought i was gonna have to do this to mine but it turned out all the crud was on the outside of mine so i just attacked the outsides of em with autosol (metal polish - probably a bit harsh in hindsight, but worked well)...
BS ive found new ones for that price even from nissan they might be pushing 3g for new
>>Brand New GTR $1300 RHS<<
>>Brand New GTR $1300 LHS<<
>>GTR headlights the Pair $1600<<
>>GTR HID $1000<<
all rough prices using Xe.com
Saw at a particular import place, can email u name via PM, $1800 each s/h.
thats kool it was prolly JMS :D there very dear and told me they were getting a GTR front cut soon
if i was ever to upgrade then i would get off yahoo japan
Close, but no. And this was about a year ago. Gotta admit, havent looked anywhere else, so i was just commenting on the basis of what ive personally seen.
i use a meguiar's plastics polish to make my headlights come up new again if ne1 is interested in trying something else and you can get it from motoquipe and so on. never tried putting em in the oven but it does sound interesting.
actually thats the reason why I was looking to get some new lights ^^^ my left light has the support inside cracked....so i was thinking of changing both if I could to s2 lights but ahh well
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
