R32 GTS25 would be the way to go, should handle quite well.
there is a r32 with a na rb25 conversion for sale at the moment are there many of them?i currently have a Nissan pulsar n14 sr20 how will it go against that? also how much do the r32s weight and are they lsd? is there a page somewhere that has all the features
The r32 gts25 was a production car from the factory they weigh high 1300kg i think. cant help you with the lsd or how they go against n14. in my opinion r32 would be quicker.
http://www.skylinesdownunder.com/index.php...0&Itemid=97
that might help
I remeber reading somewhere that N15 SSS's will have the jump on NA R33's but the Skyline will catch up a little down the line..
Quick rundown.
Short answer: R32 - No. NA 2L is poo.. if you can find one with a 2.5L thats not too bad..
If your going to get an NA skyline.. get a 33 or 34..
Down sides..
Small brakes..
Open diffs..
4 stud wheel pattern
Slap a set of coilovers and strut bars and they handle awesomly..
My NA 2.5L R32 GTS4 can keep up with higher powered cars through the twisties without too much hassle.. but you really need to keep the engine revving to get the most out of it. It is possible to have a quick NA through the twisties with the right mods.
If you want a good good handling NA your looking at the wrong place..
NA cars are all about being light weight with awesome handling..
Have a look at:
MX5
AE86
RX7 SII
perhaps an s13
Just a thought..
Quick rundown.
Down sides..
Small brakes..
Open diffs..
Have a look at:
MX5
AE86
RX7 SII
perhaps an s13
Just a thought..
could i also suggest a non turbo supra and non turbo 300zx, both these cars will make over 130kw at the wheels, and only weight about 1400kg's give or take
thanx for all the advice and info
id really like a r32 gts25 but im also looking at mr2 sprinta and 300zx im looking for a car that looks nice and goes good for na and drifts can any one giv me some advise on thoes cars or any other cars
R32 GTS25 is my pick, doesnt have VVT which does make a nice topend difference though. Ideally if you can pick up an R32 GTS25 that has already had the very easy to do 3l bottom end conversion, then you can achieve 150rwkw+ with the right mods.
R33 and R34 if you can get a good one for cheap then why not... But ultimately, I wouldnt spend too much on an N/A as a P plater cos you'll eventually get onto the turbo bandwagon later, save the dosh for a turbo car then :D
Z32s are a nice bus, not a fan of the big veee-six however, and no where near as easy to work on if you are inclined that way.
If you want to hang your arse out.. dont go for MR2.. incredibly hard to drift.
Again.. if you want to drift, you want the lightst car possible, Sprinter. There are a couple of 4AGE converted ones already and they are a blast to drive!
I see where your comming from with an R32 as a drift car but the NA's have too many down points (in my opinion) to bother with.. no time. Im pretty sure that the NA's have a weaker box too.. and thats something you dont want in adrift car.
How about a KE70?.. It would need work.. but they are quite cheap..
MA70 (is that the right code?) Supra?
Toyota Cressida?
Ghetto Spec R31 boro drift car?
i had a look at a 300zx last nite,drove nice but yes big and heavy,sprinters are sik but there bit old,r32gts25 would be awsome if i could find one wat about r33? they any good i dont really like the look but i could settle for one,ye i read about mr2s being hard 2 drift because of the heavy rear end
  • 2 months later...
  • 1 month later...
If you really want to skid it and not just a passing fancy, jump on the Aus spec R31 bandwagon and don't look back. S13 front sus, locked diff and away you go.
If you want something thats actually nice but still cheap, I'd go NA 33 and if you are cashed, NA Supra.
If you want something NA and fast, get a V8 falcon or commy. Big cam, good free flowing exhaust, some head work and either a big carby or a good EFI system and it should be quick enough to give you a scare or 2.
  • 1 month later...
Hey Mate,
Don't know if you have bought your car yet, but i got an R32 GTS 2.0L, and i have to say it's great.
There are some small downsides though
Small engine capacity means you need to keep the revs up for any decent power.
As for drift yeah a LSD would be nice but hard to source, but great in the wet ;)
handeling: as i only have a standard one at the moment i can only go by a standard setup, which is a fair bit of fun but could be a bit stiffer.
Hope this has helped you a bit..
By the way expect to pay a fair bit nowdays as P platers are only alowed non turbo ones, so they are in high demand..
Cheers
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
    • I spotted a black C34 in Mittagong this morning!
