All depends on your aim. If you just want to cruise around, look good etc then i would say 19s are the best option. Cause at the end of the day, unless your pushing hard through corners on a track, your upgraded rims are merely there for looks purposes. And 19s offer a good balance between rim and tire to create a nice look imo
https://www.sau.com.au/forums/topic/215711-18s-or-19s/#findComment-3811669
hey guys i like the ride hight of my car with the stock gtr wheels, if i was to go 19's with 35 profile tyre would wheel diameter stay same or would it b larger ?
cheers
The profile is merely a percentage of the width. Therefore, we would need to know the fullspecs of the tire size before judging whether the diameter will be larger
https://www.sau.com.au/forums/topic/215711-18s-or-19s/#findComment-3814297
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
